Results 1 to 9 of 9
    Established Member Two Rings e-baby's Avatar
    Dec 20 2008
    Sylmar/ santa clarita
    az i need your! help issue with my car
    so here's the deal my car (2005.5) starts to jerk when i accelerate. It starts at a little higher then the 2000 rpm range and mostly when i"m going up a hill, it"s like a studder feeling. So today i take it to the dealer and they inspect it and little do you know they find basically nothing wrong with it but the engine sounds louder then usual. i test drove it with the technician and it doesnt do it. so they clean my throttle body and add fluid to my trans. 200 dollars out of my pocket later and they still didnt fix the problem. There has been no check engine light. Has anybody had this same problem this is really frustrating to the point where i have no idea what to do especially as soon as i get home it starts up again
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 16 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Re: az i need your! help issue with my car
    Quote Originally Posted by e-baby View Post
    so here's the deal my car (2005.5) starts to jerk when i accelerate. It starts at a little higher then the 2000 rpm range and mostly when i"m going up a hill, it"s like a studder feeling. So today i take it to the dealer and they inspect it and little do you know they find basically nothing wrong with it but the engine sounds louder then usual. they clean my throttle body and add fluid to my trans. 200 dollars out of my pocket later and they still didnt fix the problem. There has been no check engine light. Has anybody had this same problem this is really frustrating to the point where i have no idea what to do.
    Have you ever driven a manual awd car before? Its a little different than 2wd...
    Dec 20 2008
    Quote Originally Posted by NorcalPB View Post
    what is this suppose to mean.. my car is automatic and the front track system 2wd
    Jul 16 2008
    San Francisco
    Sorry I thought you were awd and manual. Driving one for the first time seems to fit the description you put forth. Sorry I can't help you on this one.
    DUH! an Audi
    los angeles, CA
    i havent heard of this, maybe its your MAF or something...coil packs? running in limp mode? but if you took it to the dealer, they would have checked that...
    try to run vag regardless, sometimes codes are stored or ready to come on.
    Jun 25 2007
    b7
    Bay
    wheelspin
    Jan 13 2009
    Jaguar XK, Galant VR4, Mitsubishi Starion, GMC Beau James, Yamaha 650 Turbo
    Pacific Northwest, USA
    I'm new and don't know these cars well yet, so forgive my ideas if they are way off....is there a chance you got some cheap gas? I don't know where the tank pickup tube is located in our cars but if it were to the rear I could suspect possible water contamination. This could show up driving up hill...
    How about tank pump pressure? Weak?
    Sorry, kinda thinking out loud on that uphill symptom.
    Vince
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
    Apr 18 2008
    Jacksonville, FL
    your incredibly poor grammar in the thread subject that grates my soul notwithstanding, my car does something that could be described that way when it's really cold. see http://www.audizine.com/forum/showthread.php?t=251552
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Dec 20 2008
    It's not wheel spin because it"s not like i'm speeding up the hill. I know this is not normal because my car just recently started doing this. And as for fuel i always use 91. Today while driving it wasn't as bad but as i would go up hill or a little incline it still jerked a little bit. I'm thinking that it may be the transfluid because when they checked it out yesterday they said it only had two quarts and they filled it up to five (the level where it"s suppose to be at).
    But if the trans. fluid was the case wouldn't the problem be fixed as soon as the dealer added more fliud and drove it, or does it take a while of running the car before the fluid cycles the transmission.
