Results 1 to 13 of 13
    Jan 13 2009
    Jaguar XK, Galant VR4, Mitsubishi Starion, GMC Beau James, Yamaha 650 Turbo
    Pacific Northwest, USA
    Stock turbo question
    Question for those of you in the know....
    The A4 is my 4th turbo vehicle, and the first one I have ever heard the turbo "spool down" after shutting off the engine. Pretty sure it is the turbo from the sounds pitch and location (doesnt do it all the time). This cant be normal for this car can it?
    My three priors were all Mitsubishi turbos, and they were dead silent on spooling down.
    I'm wondering if the bearing are going away...
    Thoughts?
    thanks
    Vince
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Re: Stock turbo question
    It's not the turbo. It's the AC compressor. If you turn on the AC and turn it off, you can hear the sound at different times.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Jan 13 2009
    Quote Originally Posted by Zebman View Post
    That would be awesome, I'll go play with the system a bit to see if I can replicate it regularly. I know AC can run on occasion just a part of the environmental controls, but its been in the low 30s here for the last two weeks! Still... makes more sense (and less worry)that the turbo.
    thanks
    (Wish it would warm up so I can go get under this hood for a day....brrrrrr)
    Dec 03 2008
    2005.5 Brilliant Red A4 2.0T
    Ann Arbor, MI
    This is my first turbo vehicle and I've also heard the sound that you describe. I just thought it was normal.
    Aug 08 2008
    2017 Q5
    Houston, TX
    yeah, my first turbo as well. and it seems normal. i always thought its just the fan/belt slowing down. no matter if its the ac/heat/fan or what have you. it always comes on unless i turn it off completely
    Jan 13 2009
    Pittsburgh
    That is the sound of the turbo. Compared to the old 1.8T the newer 2.0T run for a few seconds after the car is turned off.
    Jan 10 2007
    VA
    ^ no it's not. it is the AC compressor. 1.8Ts do it as well. Sounds like a space ship powering down. Turn you HVAC to 'off' and you won't hear it.
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Quote Originally Posted by b6onboost View Post
    Lol that's exactly how it sounds. I've always wondered what it was too, but I never thought it was the turbo.
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Jan 14 2008
    2006 A42.0TQ 6MT
    Branford, CT
    I always figured it was the fans slowing down, but if the sound isn't present when the ac is off then there you go.
    Jan 13 2009
    Pittsburgh
    I always assumed it was the turbo. My 1.8T caused a buildup of sludge in the engine and ended up costing me a fortune to fix. The dealership said they fixed that problem by allowing the turbo to run longer and that was what the sound was. But if it's the AC.....I guess I'll have to keep fooling myself and my friends!
    Veteran Member Four Rings Insane_Audi's Avatar
    Jan 25 2009
    '06 A4 Black S-Line Ti 2.0TQM
    University of Hartford, CT
    Quote Originally Posted by Phantom08 View Post
    That is why there are turbo timers, to let your turbo run a little so if your in a hurry the turbo can cool down after the engine being shut off. It saves a lot of miles on your turbo.
    Jan 13 2009
    Quote Originally Posted by Latin Audi View Post
    Yeah, my only fear was that it was a BAD turbo, not that one would normally sound like that. The car is too new to me, so I haven't got a boost gauge installed yet either.... Don't have a clue if I am even getting full boost cause the powerband is so flat.
    My stockl '91 Galant VR4 (also an AWD car) would slam you back in the seat when the unit spooled up. My A4 isn't nearly as quick, which for a car 14 years newer is kinda disappointing. Still, I think the A4 has an extra 400lbs or so to push around over the Galant too.
    Quote Originally Posted by Insane_Audi View Post
    These are a "must have" if you choose to run standard oils instead of Synth (IMO).
    V
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Hmmmm .... this is indeed interesting because I park in a garage nest to a wall and I have excellent hearing -- my car makes zero sounds when I switch it off. Other than seeing the turbo I hardly know it is there at all. I am not running my AC at this time either (car is on Econ), so my car's behaviour supports the theory that it is the AC compressor. Either way it is not the turbo.
