Results 1 to 6 of 6
    Veteran Member Three Rings ZachPDX's Avatar
    Jun 09 2008
    PDX
    "right main beam" on display, how long do I have?
    Started getting this whenever I turn on my headlights a few weeks ago, called sunset today and they said my right headlight was on its way out, 300$ but to drive it untill it died... any ideas how long i have? 5300k miles and less than 30 days outside factory warranty, figures.
    05
    JHM SM/LW Flywheel + Stg3 clutch | JHM Piggy's | Milltek nonres | JHM Tune | JHM 4:1 Center Diff | Neuspeed 25mm Rear Sway | APR snub | Apikol Rear Diff | JHM SSTS | Vogtland GT's
    SomeGuyInAChair - "I'll be honest about why I signed up for a car forum without thorough knowledge of cars. I merely did a Google search with the following key words: "milf cougar forum advice help tips"
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Re: "right main beam" on display, how long do I have?
    get a new one off ebay. and DIY
    Jun 09 2008
    PDX
    so 15k miles later error is still there, lights still work. The error is getting old, what bulb is the "right main beam".
    05
    Senior Member Two Rings mfresh2k2's Avatar
    Jun 23 2008
    Florida
    it should be your DRL bulb, do you have DRLs?
    H&R springs, Koni Yellows, S4 caliper spring clips, clear corners, RS4 Grille, LEDs, painted rear valance, 15% tint
    Jun 09 2008
    PDX
    Quote Originally Posted by mfresh2k2 View Post
    i do not
    05
    Jun 23 2008
    Florida
    not sure what it is then, someone should know on here tho
