Results 1 to 6 of 6
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    Question Help Meth Owners!
    how did you guys tune the car once you installed the meth kit ... revo sps?
    *JUGGERNAUT*
    (Revo Stage II + HPFP File, AWE Cat Back, DMH Performance Electric Cutout, Forge Diverter/Spacer, Carbonio Intake, AWE FMIC, Snub Mount, RS4 Motor Mounts, S4 Big Brake Kit, E Code TestPipe, KW Variant 3 Coilovers, H Sport F & R Sways, KMD Fuel Kit, KMD Cam Follower, NGK Colder Plugs, Boost Gauge, South Bend Stage 3 Clutch, ECS Light Weight Pulley,Custom Inlet Pipe, 034 Street Mount, Apikol Rear Diff Mount, JHM SS Kit W/ Linkage Upgrade And Weighted Knob Lo Jack
    276hp/331tq
    Veteran Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    Re: Help Meth Owners!
    Yes SIR!!!!! I run 7-8-9 right now since its cold here in jersey and i also have the awe front mount. I had it lower but when danny dynoed my car he cranked it up more because my car was handling it fine. I wouldn't go higher then that though but I guess you could. I'm probably going to be down tuning it once it get like 100 degrees again lol oo yea and i did use the revo SPS
    B7 A4.... 394awhp
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    what would you down tune to ... and do u feel the difference tuned obviously nd yea im gunna bring it up by danny aswell but if i can get the basis to work off of so it wont b so much time on the dyno yanno
    *JUGGERNAUT*
    276hp/331tq
    Jun 26 2008
    New Jersey
    you should be good at 6-7-9 but if you want to be extra safe 7-6-9 would work well to. Let me know what you dyno when you get it done. If your getting it done soon just keep it at 7-8-9 that way you'll save some time and if it running well like that then i guess he'll crank it up even more but i doubt it. But if he does change anything let me know what setting your gunna do.
    B7 A4.... 394awhp
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    yea def om gunna put the kit in next week and ill go there nd well c wha happens lol
    *JUGGERNAUT*
    276hp/331tq
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    im running stage 2+ and with meth i use 6-7-9 on cold nights and 6-6-8 for the warm florida days... i see no point in trying to make power in the heat i gave up... i run it sextra safe and conservative and then rip it really agressive at night :)
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
