Results 1 to 23 of 23
    Established Member Two Rings 02QuattroA4's Avatar
    Sep 29 2008
    2002 Audi A4 1.8T Quattro
    Southern California
    Reaching my Goal
    I wanted to know what i would need in order to reach 300hp on my 2002 Audi A4 Quattro 5-speed. im completely stock and i want to know if this is possible without having to upgrade turbo. i have been reading posts and most talk about upgrading the turbo and injectors. im also looking for realiability. suggestions would help. i want to be at 300 hp by april. thanks in advance
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    Re: Reaching my Goal
    300 crank or wheel. even 300 crank hp will be tough on our puny ko3's. very tough. they just won't flow enough air.
    Oct 16 2006
    Naperville
    Best u would do is stage 1+ for about $950 which will be around 235 crank.
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    Money!
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Sep 13 2008
    Western Chicago Burbs
    sell your car and get an 01.5 and up b5 s4. then stage 2+ it and you will be in the 400hp 400tq range.
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Quote Originally Posted by 02QuattroA4 View Post
    There is virtually no way to get 300hp on our cars with the stock turbo. An attempt to do so would put many of the engines components at serious risk. Having said that there are 2 alternatives to look at ... First a couple of owners (Avanteix and Jet Jockey) have run MTM k04 setups that approach the numbers you are looking for. Or I run the AWE GT28r kit and just dyno'ed smack on the 300 hp mark and 300 ft/lb torque.
    At a minimum you will need the following :
    injectors
    software
    turbo
    front mount intercooler
    exhaust
    and miscellaneous installation parts along the way
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    May 21 2007
    Florida
    ^very minimum. to make it safe youll need suspension and brakes too.
    2018 Navarro Blue Q5
    Jul 06 2007
    Bremerton, WA
    Quote Originally Posted by doublezero30 View Post
    i would worry about a clutch before worrying about suspension and brakes. but all three are a good idea in addition to the list above
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    PM greg the moderator.... actslub9 i think it is... he has a MTM k04 kit that i think he might sell.. so talk to him.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by B6JoeA4 View Post
    orly lol?
    Quote Originally Posted by QuattroRocket View Post
    injectors
    software
    turbo
    exhaust
    op you can make 300 Bhp with a k03. id say high 200's with full bolt ons and water meth easy, get aggressive with your timing and you could probably break 300 crank. water methanol injection does a lot
    Jul 06 2007
    Bremerton, WA
    Quote Originally Posted by ThirdStrike View Post
    orly lol?
    who has dyno'd number like you are talking on stock turbos? off the top of my head i can't think of anyone getting close to those numbers. maybe with the 2.0t motor, haha
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by thebikedoctor33 View Post
    i know a guy local that made 218whp with 6 degrees of timing with w/m injection, giac software, and full bolt ons.
    i also know a guy that never dynoed before he upgraded his turbo but was running 9 degrees of advance on a daily basis(full bolt ons)
    tuning makes a huge difference.
    op see my sig. dont be deterred. just do it
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    there is a guy local here who made 260whp on a jetta ko3
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Jul 06 2007
    Bremerton, WA
    Quote Originally Posted by eurogruppe View Post
    damn, that is pretty impressive. i guess it might be possible to get 300chp out of the ko3. although, 260 thought a fwd car is a bit less on a quattro car, but still at or close to 300chp either way.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    just because you havent seen it dont mean its not possible
    like i said adding timing to the lil-ol 1.8 make a ton of difference. just gotta know how not to lean out.
    Jul 06 2007
    Bremerton, WA
    true true. but you have to admit, that is really going to pushing things to the limit on our turbo. and if you are planning on using the car as a dd, it might not be a great idea to push things to the limit. spending the extra 1000 for some peace of mind knowing the setup isn't being streched to the max, isnt a bad grand to spend
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    just try it. get on a really generous dyno. add ass loads of timing, every mod you can, and race gas on a nice file, modify your WG, and you might be able to do it.
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    bling bling
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    If you're going for reliability trying for 300hp on a K03 is retarded to even think about. There's nothing unreliable with a bigger turbo setup that's been finely tuned w/supporting mods. Just get a GT28RS with REVO software and call it a day.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Sep 29 2008
    Southern California
    injectors
    software
    turbo
    exhaust
    This is most likely the way i will be pursuing. thanks for all the help. i really appreciate it. How much do you think this setup will cost. estimates.
    Sep 29 2008
    Southern California
    http://www.ecodetuning.com/shop/cart...t_detail&p=567 or i want to go with this. what else do i need other than this.
    Jun 08 2008
    Calgary AB Canada
    full exhaust, intercooler, clutch
    better off getting this for less: http://www.ecodetuning.com/shop/cart...t_detail&p=504
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Quote Originally Posted by onceover View Post
    +1 to that.
    Also need a few simple things like high-flow filter/intake, DV, TIP.
    Your price really depends if you want/can find used parts and if you are going to DIY most of the work or have a shop do it all.
