Results 1 to 28 of 28
    Senior Member Two Rings unh112's Avatar
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    Smile Symphony II to II +
    Is it just a simple plug and play? Bought a plug from euro-parts.us and is that all I need? I've search but found nothing. Not a lot of people are doing this I suppose. If someone has a DIY it would be great.
    06 B7 Quattro Silver MT
    RS4 Sway Bar | RS4 pedals | S4 Door blades | Votex front spoiler | Votex rear spoiler | revo stage 1 | Forge DV | clear side markers | VAG-COM mod | Eibach pro kit | Koni FSD | 40% Llumar axcess tint | LED license plate light | 6000K HID | 18's B8 wheels 245/40/18 tires with 8/12mm H&R spacers front and back
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: Symphony II to II +
    is symphony II + the one without the cassette tape opening?
    i want it too. does the symphony II + read mp3 cd's?
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    Yes and yes. Theres a listing on Ebay right now, starting price really cheap. Grab it before anyone else does.
    http://cgi.ebay.com/ebaymotors/2007-...shQ5fReceivers
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    nice, then i default to your original question as well, is this a direct plug in? do i just need the 4 stereo removal rings?
    i would like to pick up the rns-e, but i already have a garmin navigation system that i'm really happy with. i'd rather dump $1k towards wheels or an exhaust.
    [edit] - this link might help. it shows how to retro fit into a b6:
    http://forums.audiworld.com/a4gen2/msgs/1067234.phtml
    Senior Member Three Rings MichiganAudiDvr's Avatar
    Nov 19 2008
    2007 Audi S4; 2007 Chevrolet Tahoe LTZ
    MI
    Easy Diy For Symphony II To Symphony II+ Install
    I went from a Symphony II to a Symphony II+.
    With the proper harness from euro parts (symphony II to symphony II+ (specify with or without Bose, it matters)), the diversity antenna adapter (a must have for good radio reception), and the removal rings you will be all set.
    1. Insert keys - pull to remove the old unit, disconnect all wires.
    2. Connect the euro parts harness to connections in dash before connecting to unit, it's easier - (you will have one unused plug on your harness which is for the phone (I assume you probably don't have the phone hookup) so nothing gets plugged in there.
    3. Take the diversity antenna connector from the old unit (tan square with a pink clip on it) - remove the small pink clip and remove the tan plastic housing so you are down to the metal connector on the wire. Insert this wire into the empty space on your diversity antenna adapter by removing the pink clip on the diversity antenna adapter and inserting the wire and then putting the pink clip back in.
    4. Connect the "cable tv" looking antenna cable to the other side of the diversity/antenna adapter.
    5. Plug in the square block harness adapter to the unit and lock it in using the built-in lever.
    6..Plug in the diversity antenna adapter to the unit.
    7. Ease the unit back into the dash, pushing the harness and extra wires out of the way. TEST THE UNIT and be prepared to enter your key code - make sure it unlocks.
    8. If everything works, push unit the rest of the way into the dash. Hopefully hear 4 clicks as each corner locks into place.
    *PS - No need to disconnect the battery for this swap - some threads say to disconnect.
    *PPS - Some people are having problems with the OEM iPod adapter after this swap. I don't have an iPod adapter and thus had no trouble. Some have suggested that if you have the iPod adapter that you SHOULD disconnect the battery to avoid a problem here. I can't confirm or deny this information.
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    Yeah i have a Garmin GPS as well. I read this link before but its telling me to get all these connectors.
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    Re: Easy Diy For Symphony II To Symphony II+ Install
    Quote Originally Posted by MichiganAudiDvr View Post
    *PS - No need to disconnect the battery for this swap - some threads say to disconnect - totally unnecessary.
    Thanks very much for the DIY!!!!! What if I dont have the code, anyway to retrieve it without paying the stealership??
    Established Member Two Rings Mtepete's Avatar
    Jun 17 2008
    2005.5 A4 Black 20% Tint
    Hartford, CT
    im thinking of doing the same thing but i want sirius as well, currently i dont have satalite radio is there anything i would need to buy addionally to connect the antenna for satalite radio i fiugre if im gonna do this it might as well be all at once.. sorry to high jack..
    Brilliant Black 2005.5 A4 2.0T 6 speed
    Stage I REVO
    RS4 Grill, Painted Reflectors, Yellow Lamin-X Fogs
    EVOMS Intake, Classy Tint
    AWE Diverter Valve
    Sirius OEM Module
    Nov 19 2008
    MI
    Quote Originally Posted by unh112 View Post
    Unfortunately, I don't think so.
    Nov 19 2008
    MI
    Wink Simple Diy For Sat Radio Install
    Quote Originally Posted by Mtepete View Post
    Luckly, I have done this as well - I had no sat radio when I bought it. I added the newest revision of the XM module to my car - I purchased the receiver on here on the forums.
    The install is very easy.
    1. Once you have the receiver all you have to do is go to the left side of the trunk, open the cubby door, and pull out the tray, it looks like rectangle block with two screwdriver pry sections on the bottom. Take a cloth over a screwdriver and pry open (opens like a drawer). Pull it all the way out.
    2. If you stick your hand way back there (and to the right) you will find the harnesses for the XM and/or Sirius radio (you will feel them and see them when you pull toward you). The wires will be folded back on themselves and zip tied by the factory to keep them out of the way and from bouncing around (you will know what I mean when you see it). Carefully cut the zip tie and remove any foam that might be covering the plastic harnesses.
    3. Slide Sat receiver into tray/drawer and secure with screws (you may have the screws) or secure with double sided tape on the tray.
    4. Slide the drawer back into the slots on the cubby. You are now done in the trunk. YAY!
    5. Go and test your sat button - If it works - great - but more than likely it will still say "No Sat Radio" or something to that effect. If it does not work you have one more important step.
    6. Go here: http://audi.barrystuff.com/s4/satRad...sat_canBus.pdf
    You have to switch the CAN BUS connection near the passenger foot well - Don't be intimidated - this is a peace of cake. Don't be afraid to pull straight up on the plastic molding. Removing the CAN BUS connector is tricky - I fought with the dang thing for over 20 minutes before I was able to sneak it out. It has some kind of clip on it to release it and I couldn't figure it out for a while, then it just popped out on me. So, if anyone has a trick on this (besides playing around with it for 20 minutes) feel free to post. Really - it's easy. Once this connection is switched - see photos and directions in PDF, you are done and you just have to call Sirius or XM to set up.
    One more thing - look at this website (link below) for "photo help" but know that this dude is a complete idiot because he didn't realize that the black rectangle is a tray that pulls out. Audi would never design a radio install that would require the dumb ass shit that he did in this DIY. You can see the "rectangle" drawer in his photos, apparently he never realized that the "drawer" was his access, not removing the entire side of the trunk wall. But again, his photos provide some reference to what I have inserted above. You don't need his tools or anything, so forget the rest, really.
    http://www.audiworld.com/tech/elec121.shtml
    I hope this helps - and enjoy - and if you like my last 2 DIY posts, help by bumping my reputation using the little thumbs up and down in the left side gray area!! Thanks.
    I hope this helps you guys (and girls).
    ***One more thing - If you have not yet purchased a receiver you can call your local audi dealer to ask which sat radio modules will work with your vehicle - he gave me 4 different part numbers for mine. 2 for XM and 2 for Sirius - the original and then a newer part number for the revision (much like our many revisions of diverter valves) - In this case the newer part (the revised part number) will allow you to connect your sat radio to the Navigation Plus system if you ever decide to upgrade to the Navigation Plus system, whereas I don't think the older revision will work with NAV, but it will work with all other units. Enjoy
    Jun 17 2008
    Hartford, CT
    Re: Simple Diy For Sat Radio Install
    thank god for people like you hahaha
    Stage I REVO
    AWE Diverter Valve
    Sirius OEM Module
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    what's the ballpark on getting an estimate for getting the stealership to reprogram the head unit if it doesn't come with a code? are we talkin' 50 bucks, 100 bucks, 250?
    Established Member Two Rings remOOOO's Avatar
    Jul 10 2008
    A4/B7 Avant 2.0T Quattro
    Naples FL
    go to telematics forum there is a couple threads about that.
    retreving pin at audi is something around $100
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    Damnit!!! I guess anything to make a few bucks in this economy.
    Veteran Member Four Rings ataylor's Avatar
    Dec 15 2008
    snowboarding, computer, and mountain-bike parts
    Golden, CO
    uhh. I want that Symphony II on ebay. I'm bidding on it, sorry. Are you as well?
    History: MK3 Jetta 2.0 MT; MK3 GTI VR6-SC; B7 A4 6MT STG2; B8 S4 DSG; B8.5 S4 DSG
    Dec 15 2008
    Golden, CO
    haha well someone was sitting on it for $130, and now is paying at least $210 thanks to me.. idk if I wanna spend any more than that on something so similar to what I have. I searched for Symphony II and got a bunch of swap/install threads.. gonna have to research some real benefits besides losing the ugly tape-deck. Any thoughts?
    Jul 10 2008
    Naples FL
    plays mp3 cds, you can add easly AUX IN for mp3 players (clean oem look), much better sound, you can mute with one touch, great display.. and it is easy to swap :D
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    you guys suck, Ive been watching that auction for a week. One just sold for for 160 or 170 a few days ago, i didn't bid thinking i was going to pick this one up cheaper.
    Dec 15 2008
    Golden, CO
    much better sound? so it uses a different processor or something too? I like the convenience and technology improvements youve mentioned anyway...but I thought better sound was really unattainable without upgrading these speakers..which seem to choke out when you really push them.
    Jul 10 2008
    Naples FL
    wow $160 is an awesome price. I've got lucky and bought mine from AZ for $200 shipped. usually they sell for $250 plus shipping
    well bass is nicer (much deeper, treble are nice and clean, mid is ok) all that playing not so loud. I'm not saying that its going to be loud and crazy but more balanced.
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    Quote Originally Posted by remOOOO View Post
    HAHA i was the one who bought the $170 one.....
    Veteran Member Four Rings Koby's Avatar
    Aug 05 2008
    Easton, PA
    How do you add the AUX in on these? Thanks...
    Established Member Two Rings Bart-Man's Avatar
    Aug 19 2008
    06 audi a4 2.0T
    Wondering if the Audi A3 Symphony II+ will fit in our a4's.
    Established Member Two Rings NjKreuzer27's Avatar
    Feb 05 2008
    Clifton<NJ
    I thought all the b7 came with the symphony II+.....anyway how did ur install go looking to do the same with my b6
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Quote Originally Posted by NjKreuzer27 View Post
    x2.
    Established Member Two Rings rhumen's Avatar
    Feb 07 2009
    orlando, fl
    Quote Originally Posted by Koby View Post
    x2
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    more info please
    Dec 11 2008
    '08 A4 Avant SE, '99 4Runner
    Westminster, CO USA
    An old post about adding the AUX to a Symphony II+
    http://www.audizine.com/forum/showthread.php?t=260625
