Results 1 to 2 of 2
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** 1.8 to 2.2 STROKER KITS - Increasing your displacement - KITS,TECH & FAQ ***
    PSA : PLEASE USE EITHER OF THE FOLLOWING THREADS FOR YOUR QUESTIONS:
    - B5 FORUM
    - B6 FORUM
    Since the introduction of the 1.8T engine in North America,sourcing stroker kits have been limited to 1 source.
    Fast forward a couple of years and we are now able to offer you every possible configuration that your heart desires :cool:
    Combinations range all the way from 1803cc's to 2190cc's!
    1803CC KIT - MAHLE PISTONS
    This is the introductory level kit for those of you who want to do a simple hone on a tired block.This kit includes Mahle Pistons which are superior in design & construction when compared to anything else on the market.
    Kit includes:
    (4) - SCAT 144mm/20mm Forged Connecting Rods
    (4) - 81.5mm Mahle Forged Pistons w/ 9:1 Nominal Compression Ratio
    $999.99 + Shipping
    1803CC KIT - JE PISTONS
    This is the introductory level kit for those of you who want to do a simple hone on a tired block but with the more affordable JE Pistons.
    Kit includes:
    (4) - 81.5mm JE Forged Pistons w/ 9:1 Nominal Compression Ratio
    $969.99 + Shipping
    1870CC KIT
    For the user looking to really *open* up his block.Very popular kit amongst those users looking to increase displacement without changing the stroke.
    Kit includes:
    (4) - 83mm JE Forged Pistons w/ the following choices of nominal compression ratio:
    * 9.5:1
    * 9:1
    * 8.5:1
    *** 83.5mm Pistons available upon request ***
    $969.99 + Shipping
    2008CC KIT
    The most popular kit of the lot for the 06A block,a full "2.0" kit using a Forged OEM crankshaft from the 2.0FSI motor along with OEM quality Forged Supertech Pistons.
    Kit includes:
    (1) - 92.8mm Forged 2.0 FSI Forged Crankshaft with correct Oil Pump gear to utilise the stock 1.8T oil pump
    (4) - 83mm Supertech Forged Pistons w/ 8.9:1 nominal Compression Ratio (82.5mm bore available upon request)
    $1699.99 + Shipping
    2190CC KIT
    NOT FOR THE SOFT!!!
    This is a kit for the very serious VW/Audi owner who wants a manly 100mm stroke crankshaft & paper thin cylinder walls.
    Kit requires the purchase of the ALH 236mm TDI block.
    Kit includes:
    (1) - 100mm Eurospec Forged Crankshaft with correct Oil Pump gear to utilise the stock 1.8T oil pump
    (4) - SCAT 159mm/21mm Forged Connecting Rods
    (4) - 83.5mm JE Forged Pistons w/ 9.5:1 nominal Compression Ratio
    (10) - ARP 12mm Head studs to allow the use of a 20V head on an ALH block
    $2699.99 + Shipping
    INDIVIDUAL PARTS:
    Main Bearing Girdle Kit - 058 Block $480 + Shipping
    Main Bearing Girdle Kit - 06A/06B Block $580 + Shipping
    Billet Main Bearing Caps: - $139 + Shipping
    AEB MACHINED IM SHAFT - $105 + Shipping
    034 Motorsport Anti-Friction Main & Connecting Rod Bearings - $215 + Shipping
    BIG BORE Head Gasket - $95 + Shipping
    ARP Main Stud Kit - $135 + Shipping
    ARP Head Bolt kit - 06A - 10mm - $175 + Shipping
    2.0 ABA FORGED - 058 - 92.8mm crankshaft - $375 + Shipping
    2.0 AEG CAST -06A - 92.8mm crankshaft - $375 + Shipping
    2.0 TFSI FORGED - 06A - 92.8mm crankshaft - $874.99 + Shipping
    Supertech 82.5mm/83mm Pistons - $589.99 + Shipping
    SCAT Forged Connecting Rods - $369.99 + Shipping!!
    PAUTER Forged Connecting Rods - $779.99 + Shipping!!
    PAUTER Forged Connecting Rods w/forced pin oiling - $939.99 + Shipping!!
    RACEWARE Head Stud Kit - 10mm/11mm - $469.99 + Shipping
    Please send me a PM when you are ready to order and please select which displacement you desire ;)
    Thanks :beer:
    p.s. Some assembly may be required :laugh:
    Feb 26 2006
    Earth
    Re: *** 1.8 to 2.2 STROKER KITS - Increasing your displacement - KITS,TECH & FAQ ***
    All PM's replied to
