Results 1 to 40 of 65
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    SAI - Removing it without actually removing it?
    Paging Old Guy, Diagnosticator and probably Greg as well.
    So, this is my engine bay:
    Not a lot left.
    But, I'm getting tired of the check engine light being on from removing the secondary air injection, so I'm contemplating putting it back on. BUT, I want to do so in a manner that doesn't involve putting everything back on for it.
    So, before I get to work, I want to run an idea past everyone to 1) see if my understanding of the SAI system is correct and 2) find out if my idea could even possibly work.
    My understanding of the SAI system is that when the car is started cold, the SAI pump kicks on and pushes air into the EGR valve, which feeds extra unmetered air into the engine to make the car run leaner (and thus hotter) for a few moments to warm up the catalytic converter faster.
    Correct?
    SO, with that said, will I be able to fool the car into thinking the EGR and SAI are still present if I were to instead put the SAI pump back on the car and instead of having it feed the EGR valve (which I would like to leave off), have it force air into the TIP (post-MAF, so it's unmetered), which would cause the car to run slightly lean?
    Thoughts? Ideas? Suggestions?
    -Darrick
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: SAI - Removing it without actually removing it?
    Quote Originally Posted by Capt. Obvious View Post
    That is correct. It puts additional air into the exhaust ports in the head to lean out the exhaust mixture for cold starts.
    I don't believe its an EGR valve per-say.
    Your code is for insufficient flow. In your case it is because there is no flow in the head. Where the ECU is sensing this? I do not know. I don't believe there is an electrical connection on the valve in the back of the head. That only has a vacuum line coming from the N249 valve (I think thats the valve). Trying to recall my car (SAI is completely removed) the only electrical connection I have is the SAI pump itself.
    I know you don't want to do this but I would try to hook up the valve on the head and run the lines under the turbo and relocate the pump back to where it was. You'll basically be putting the system back in but hiding all the lines so the only thing you'll see is the valve on the back of the cylinder head.
    The key here is that the additional air is post combustion. That is how the factory can get away with leaning out the mixture. You don't want to lean out any mixture for combustion itself.
    OR, you can talk to kompressd and he can set readiness to 'okay' for you within your ECu. That will allow you to keep the SAI system out of your car.
    -Doug
    Nov 14 2006
    Gig Harbor, WA
    Is this a VAG-COM tweak of some sort, or is it in conjunction with ECU software?
    -Darrick
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    SAI is a ULEV requirement, has no real affect on how the car runs. Contact David @ Eurocode, he can take care of the MIL for you.
    May 24 2007
    Southern California
    Quote Originally Posted by 400HPA4 View Post
    ^^I need to do this soon
    Kyle
    2.0L Revo GTRS Eliminator
    Dec 03 2005
    2 pedals 1FG
    connecticut
    He'll physically go into your ECU and change a few things. You can not do this with VAG-COM. The only way to set readiness to 'good' is to physically tweak a few files on the ECu.
    Its more than just setting readiness to 'good' too. You need to change a few maps to set the cold starts up properly. Otherwise cold starts will be rough.
    What software are you running? If REVO, follow Greg's advice.
    -Doug
    Nov 14 2006
    Gig Harbor, WA
    Cold starts have been perfect. It's been in the teens and 20's here and it fires right up every morning.
    -Darrick
    Dec 03 2005
    2 pedals 1FG
    connecticut
    But it probably idles rough, right? If you try to tap the gas it'll probably stall?
    -Doug
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Does anyone know how much Eurocode charges to do this? Perhaps in conjunction with buying a BT software flash?
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Apr 20 2007
    Lander, Wyoming
    Perhaps it infers it from the lower than expected EGT's when the pump isn't running.
    Jon
    go > show
    Ich liebe mein Audi
    Oct 22 2005
    Reppin the Mitten.
    My sai is removed, and my car doesnt get a code....not anymore at least. It does get triggered once in a while if i don't let my car sit and warm up enough before I drive it. I have revo's file.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by vinny.dtw View Post
    This is an intermediate check that throws off the CEL. It won't happen on every start-up.
    Dunno the specifics of what triggers it, Jon. Only thing I really know is my car was reprogrammed and I was told a little bit about everything that was reprogrammed. And when the changes were made my cold starts and idle and just off idle functionality turned back to stock-like from having a rough time.
    -Doug
    Oct 22 2005
    Reppin the Mitten.
    Yea, but my idle is perfectly fine. In the cold of 1 degree to 32 degrees. So who knows, there's no point with me having the SAI since i don't even have a fricken Cat anymore
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    I never had a single problem with cold starts or idles when my SAI was unplugged.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Nov 14 2006
    Gig Harbor, WA
    Quote Originally Posted by actlsub9 View Post
    Same here. No rough idle or stalling if I blip the throttle. Runs perfect. It's probably kinda like running an open diverter valve, some cars do fine with it, some run like crap.
    -Darrick
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    When you drop off the car to have the BT installed I'll have the SAI code removed from the software
    Veteran Member Three Rings orangelmo's Avatar
    Jul 05 2007
    Stouffville
    I'm assuming you guys don't have to deal with emissions testing. If you do, how do you get it to pass with everything missing?
    Jun 11 2005
    Vancouver, BC
    I don't have to have my car tested for emissions until 2014 and even if it did get tested they do it via the OBD port to see if any codes are present.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by orangelmo View Post
    They plug my car's OBDII port into their computer and scan the car. If all readiness codes pass my car passes emissions. My SAI is always set to 'pass' for readiness
    -Doug
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Thats good info, and my car does act like a carby car on cold starts in cold weather (BT, Revo, no cat, stalls on gas after real cold start). I hate the constant warning light too, but I'm not happy with Gregs source, or that they would even do it for me (where I got ALL of my stuff from). Is there any other vendor that can do it?
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The SAI system has no effect on the idle during a cold start. The SAI pumps air into the head post ignition and mixing with the exhaust outflow. The ECU is looking for a lambda integrator signal from the primary O2 sensor to determine if the extra O2 is present. Re-routing the SAI into the TIP will not work. Your only options are to have someone write the code out or leave it hooked up.
    Sorry!
    Nov 14 2006
    Gig Harbor, WA
    Darn, maybe I'll just put the EGR and SAI back on for the time being then.
    -Darrick
    Senior Member Two Rings Dopefish's Avatar
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    Capt, your engine bay looks fantastic! Any more images of it? I like the painted engine covers and clear turbo area. Is that Amulet red?
    I presently have APR Stage 1+, when I went to ETA to have the update for my testpipe added, I asked if they could write out the SAI error as well and I was told no, David wasn't around to confirm though. Does anyone know more about that possibility with the APR software? I plan to go big turbo eventually and that will included the more popular REVO software but that is quite awhile away and the CEL is annoying for such a silly thing.
    1982 Signal Green VW Scirocco
    2004 Tornado Red Triumph Speed Triple : Barracuda CF Exhaust : Woodcraft Clip-Ons : Ermax Undertail
    Audiwissen : Coming soon
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    i have the same improper/insufficient flow fault for my SAI, but my pump is still intact. ive had it ever since i installed my testpipe and cone filter, but i think i burned up my pump because i just used a vacuum cap for the inlet hose (poked about a million holes in the cap).
    there is no egr on the 1.8t as it was eliminated by using vvt to achieve the same end. the valve on the back of the head is the Combi-valve (combination). and flow is determined by signal voltage from the primary 02 while the pump is activated.
    ive just been clearing the fault every 2 weeks or so, once it sets. pisses me off because it erases my fuel trims when i clear it, but o well. ive also heard you can eliminate the pump all together by wiring in a 650 ohm resistor in its place, but you would still get the flow fault, just not an additional open circuit fault.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    May 24 2007
    Southern California
    btw way darrick, you keep your car insanely clean, being that you are in washington.
    you must get your panties in a knot when it rains. haha
    Kyle
    Nov 14 2006
    Gig Harbor, WA
    Quote Originally Posted by A4natomical View Post
    LOL, it's filthy right now, but I do try to keep it really clean.
    -Darrick
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    You need an R8 oil cap and then paint all the other caps black along with the coolant res..
    But when have you ever taken advice, lol.
    Clean engine bay.
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    I must be retarded, but wheres your intake?
    Veteran Member Four Rings Raus's Avatar
    Aug 18 2005
    B6 1.8TQM, Mk2 GTI
    Quote Originally Posted by GtiRSmiley View Post
    In that pic it I see a clamp and hose right under the headlight, looks like a custom setup pulling in air from the lower bumper area.
    Ich bin der Musikant mit Taschenrechner in der Hand
    Nov 14 2006
    Gig Harbor, WA
    -Darrick
    Oct 15 2006
    From a few to one...
    Arlington, VA
    i know nothing of what you are trying to do, so there is no way i can help.
    i just wanted to let you know that your engine bay is very pretty.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Jan 23 2007
    2006 GTi, 1986 951, 2002 a4
    Norcal - Sac area
    Wow! Must be a small guy
    OP:
    The engine bay looks really clean, what intake manifold is that?
    2006 GTI - APR K04 ~296 whp
    1986 951 - t4 50 trim ~373 whp
    2002 3.0Q A4 - Stock (Wife's)
    Nov 14 2006
    Gig Harbor, WA
    Quote Originally Posted by czero View Post
    Stock. I just polished the top of it.
    -Darrick
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    Thanks for the images, I love it! Gives me a few ideas to try out since I still think mine is a bit messy.
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    uni BT files can have everything written out of them as a free option. SAI, EVAP, N249, N112, CAT, MAF, etc.... but you have to be a uni BT customer to get this. and they are written out in a way that your OBD readiness will always display "PASS" when the emissions computer takes a look.
    Jan 23 2007
    Norcal - Sac area
    Oh ok, never seen a longitudinal 1.8t motor so I didn't know if it was stock or not.
    Oct 29 2008
    02 a4 92 gvr4 03 r6
    any updates on this? I want to remove all my vac.lines and such but i want to keep the SAI. I want it tucked away but im trying to completely understand how it all works first.
    does the n112 valve receive vac/pressure from the intake manifold? or does it just dump into the vac. reservoir? I take it the vac reservoir is sealed up? Do i just cap the other end of the n112 valve? I plan on removing everything else but cant really figure out what to do with the vac line that comes out of the n112 and heads to the rats nest of other shit.
    I am just confused which way the air flows after the it leaves the valve by the firewall and goes to the n112.
    Dec 28 2006
    Western Maryland
    The N112 is essentially the same as the N249 valve with one of the ports blocked off. It functions as an on/off switch for the combi valve. You need a vacuum source going to the N112. That would be the straight line going to the "T" in the pic below. It's the valve on the right. The curved line leaving the N112 goes to the combi valve. The ECU activates the N112 which in turn pulls vacuum to open the combi valve allowing the SAI to pump extra O2 into the back side of the exhaust port.
    Oct 29 2008
    02 a4 92 gvr4 03 r6
    exactly what i needed to hear. going to go tackle all of this today. thanks a lot :)
    Feb 17 2004
    Liberty Hill, TX
    Cap'n, YGPM
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
