Results 1 to 24 of 24
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    E-codes are they plug and play?
    I've got stock OEM HID d1s headlights in my car. I want to change them to e-codes of same set up. Are they usually plug and play or do I need to splice/re-wire them to my stock set up? Do I need to modify anything to make them fit??
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: E-codes are they plug and play?
    OEM ecodes = plug n play.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Oct 16 2006
    Naperville
    not quite plug and play.... you need to pick up some new bulbs. Turn signals and city light bulbs. also you might have to play with the harness to make it reach the housing. I just made my own adapter to add a couple of inches.
    Jan 09 2008
    California
    Quote Originally Posted by manguyen View Post
    I'm looking at Helix E-codes. I notice they label it as D1S HID housing. I already have D1S setup, why would I need new bulbs? turn signals weren't mentioned so...which ones would I need?
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    Ya for your car they will be plug and play.. Also you should know that the city light itself wont turn on, unless you VAG your car to canada mode.. Dont worry things will still be in MPH and F the only thing will be that your citylights along with your fogs will be on.. Also your interior lights will be always on and when you open your door and the car is on you will get that killer BEEEEEEPPPP. You can get around that by wiring those citylights to a feature that turns on when the key is on... aka fuse tap...
    Before installing them into your car though you will need turn bulbs because the E'code system uses a different type. Dont worry E-code turn bulbs are the generic turn bulbs all cars use, so it is E-wallet friendly.
    I bought my e-codes about 2 months back and I love them! <they look sooo much better than stock clear cornered headlights
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Jan 09 2008
    California
    Quote Originally Posted by Frey7190 View Post
    Which brand e-codes did you get? If I decide to not use the city lights, will I still have issues like you've mentioned?
    Veteran Member Four Rings Raus's Avatar
    Aug 18 2005
    B6 1.8TQM, Mk2 GTI
    What you're getting are not OEM E-codes, but regardless you will get a bulb out error without the city lights.
    Off the top of my head, on regular E-codes the city lights are W5W and the turn lights are PY21W, the easiest and cheapest place to find them is ironically at a Benz dealership. You might want to make sure that's what the Helix lights use.
    Ich bin der Musikant mit Taschenrechner in der Hand
    Jan 09 2008
    California
    Ok so from what it sounds like e-codes require some wiring/fuse tapping, and VAG-com to make them work. I've misunderstood thinking that these would be direct swap, as in unplug headlight harness from old headlights, plug in new e-code headlights and you're good to go...If it seems that it requires more to get it to work, I'll probably not go with these e-codes and just stick with my OE set-up. Unless there are e-codes out there that are direct plug and play without the extra work that comes along with it...
    Aug 18 2005
    B6 1.8TQM, Mk2 GTI
    No, you don't need to modify anything or have to use a Vag-com.
    I had xenons on my car, I unplugged them and plugged in a pair of bi-xenon e-codes and that's all there is to it if you have all the bulbs.
    Jan 09 2008
    California
    Quote Originally Posted by Raus View Post
    Really? Why am I getting mixed messages. (See above Frey 7190's reply). DO you have the Valeo e-codes?
    Aug 18 2005
    B6 1.8TQM, Mk2 GTI
    Quote Originally Posted by jonsaudi View Post
    Definitely. Re-read whay Frey posted, all that is optional and done after the fact. They're plug and play. Yes I have OEM valeo bi-xenon ecodes.
    I get what he's saying though, since I'm in Canada I didn't have to change anything. I'm pretty sure that Americans shouldn't have to. The City light runs instead of the amber corner on regular NA headlights, I thought it was all in the wiring in the headlight.
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    Wow.....I to am lost! I am in the same boat, I want ecodes but dont want to have to go through a bunch to get them to work!
    Someone please explain in more detail!
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    May 21 2007
    Florida
    i take it you are looking at the chrome helix ecodes and not the black ones? the chrome i assume are pretty much plug and play since they are labeled for d1s. just have to swap the bulbs and ballasts over. the black are only halogen, unless you do a bit of retrofitting.
    2018 Navarro Blue Q5
    Jan 09 2008
    California
    Quote Originally Posted by doublezero30 View Post
    Yes HELIX d1s HID e-codes. Do you have them too? Are they really plug and play without having to manipulate VAG or fuse tapping to make the city lights work??
    May 21 2007
    Florida
    ^no i have the black halogen housings which i spent 10 hours retrofitting my stock xenon projectors, bulbs and ballasts into. i also had to cut the harness from my stock lights and splice it onto the ebay lights.
    you shouldnt need vagcom anyway. and if there is a slot in the headlight already for citylights than you dont need to worry. if you plan on drilling one then you will need to rewire it. if you have auto leveling lights you will need to pull the fuse to keep the warning from coming on the dash.
    Oct 06 2008
    Los Angeles, CA
    So if I have auto-leveling and I buy these Helix D1S ecodes, my auto-leveling will no longer work? Is there a way I can make it work or I'm just gonna have to pull the fuse?
    Jan 09 2008
    California
    "Pull the fuse?" wouldn't that actually kick the warning light on?? Or what do you mean by that?
    Aug 18 2005
    B6 1.8TQM, Mk2 GTI
    No, he's right. The auto-levelling function as well as the warning light are gone when you remove the fuse.
    IMO it'd be better to just spend the extra $ for oem e-codes, perfect fit finish and function and no need to butcher up anything.
    Oct 06 2008
    Los Angeles, CA
    where can I buy the OEM ecodes?
    Oct 16 2006
    Naperville
    didnt know you were getting the chrome Ecodes. These was a set of them on ebay for like 300 and some change a while ago. Factory OEM ecodes. :(
    Senior Member Three Rings riot5alex's Avatar
    Jan 25 2008
    03 3.0QM
    Illvine, CA
    i jsut installed them this weekend... yea i had that prob too... i just messed around with the fitment until i got it in.
    oh yea.. what bulbs do i get for the city lights.. i forgot all about asking about those and now im getting a parking light out signal.
    Jan 25 2008
    03 3.0QM
    Illvine, CA
    Quote Originally Posted by R3K8C24 View Post
    talk to jens... lowesta4... he hooked me up.. awesome guy
    May 21 2007
    Florida
    OEM ecodes are a bit on the expensive side. thats why i did ebay helix ecodes and retrofitted them. but its up to you really. your car, your money.
    Jan 09 2008
    California
    I guess in your case, you had the stock HID d1s set up, right? Then you replaced them with the Helix black e-codes that was meant for stock halogen...explains the reason why you had to retrofit. But I'm talking about the Helix chrome ones that are meant for stock D1S HID set up. I'm guessing this chrome ones would be more close to plug and play in that case...
