I ran a scan a pulled a few errors, What do ya make of em'
I was able to enable the AUX port and disable the seat belt chime. it was so easy
I would love shut off the pass. airbag light and the door chime....anyways:
VCDS Version: Release 805.2
Data version: 20090111
Tuesday,27,January,2009,13:24:58:29293
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 32810km/20387miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E1 910 115 HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0030
Revision: 5EH15--- Serial number: XXXXXXXXXXXXXX
Coding: 0104010A18070120
Shop #: WSC 06325 000 00000
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004524
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 00003
Shop #: WSC 06325
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS 0060
Revision: SIRIUS Serial number: AUZ4Z7E2014446
Shop #: WSC 00000 000 00000
2 Faults Found:
02633 - Antenna for Satellite Tuner
009 - Open or Short to Ground - Intermittent
02635 - Tuner Not Enabled/Activated
000 - - - Intermittent
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H13 4240
Revision: 91H13424 Serial number: 0036N0G16NSK
Coding: 0032707
Part No: 8E0 910 339 D
Component: BF-Gewichtsens. H03 0080
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02021
Shop #: WSC 06325
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 N HW: 8E0 920 951 N
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0022264
Shop #: WSC 50083 136 84703
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CP
Component: Komfortgerát T7B 4236
Coding: 11820
Shop #: WSC 06325
Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
1 Fault Found:
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
Address 56: Radio Labels: 8J0-035-1xx-56.lbl
Part No SW: 8E0 035 195 AC HW: 8E0 035 195 AC
Component: R Symphony2+ H07 0240
Revision: 00H07000 Serial number: AUZ1Z4G4457707
Coding: 0210112
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
End ---------------------------------------------------------------------
Thanks,
IAN
