Results 1 to 19 of 19
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    I think my turbo died today.....
    So i headed onto the parkway as i always do in the morning. I began to accelerate and as i was approaching redline i went to shift and the car jerky violently forward and then a black cloud of smoke came from the exhaust! In all my experiences when you see a black cloud its generally the turbo. I wound up making it to work, limping here on just the 4 banger. I am not sure what to do now, i could drive the car home but i do not feel safe doing so just yet. Any advice? Anyone selling a turbo cheap to hold me over until i upgrade again?
    Can someone from APR chime in as to what you think i should do? Keith/Mike??
    Thanks
    John
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Re: I think my turbo died today.....
    John,
    By your description I can't speculate as to what happened. Maybe it was an ic hose? Have you had a chance to inspect it?
    Nov 16 2005
    mass
    Was it making boost?
    Coil pack?
    2003 RS6
    had: 2006 A4 quattro M6 2.0t
    had: 2008 VW GTI 2.0t M6
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    damn john that sucks
    Apr 14 2008
    Oceanside, New York
    Sorry for the false alarm, not the turbo..... its the pesky cam lobe, so far thats where things are pointed. the Vag keeps showing low fuel rail pressure, so that can only be the issue.
    BMW M3 ZCP
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    way to scare people!!! lol glad it came out to be something more common than a blown turbo
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    id be more worried about other things then the turbo...a ko3 turbo isnt expensive, ha but everything else is much more expensive :P
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Lol yeah I was going to say, turbo is generally white/whiteishblue smoke, not black. Good luck
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Apr 14 2008
    Oceanside, New York
    Well its off to the dealer thursday and luckily they are an APR dealer so they are going to help me out and try to warranty it. Got to love friendly dealerships.
    BMW M3 ZCP
    DUH! an Audi
    los angeles, CA
    best of luck!
    Aug 22 2007
    2006 A4 QTM6
    forest hills queens, ny
    are you going to anchor audi service?
    Jul 11 2005
    Auburn
    That's what I was thinking either Anchor or Riverside but Riverside is in NJ.
    Jan 01 2008
    Long Island NY
    good luck go stage 3 now.
    Veteran Member Three Rings 04Ultrasprt's Avatar
    Jan 13 2008
    North NJ
    hey john, let me know what comes of this, I want to know what I have to look forward to
    Previous rides:
    Lotus Elise - B6 S4 Cab - E90 335i - E46 ///M3 - B6 PES Stage 2 S4
    B6 Nogaro S4 - B5 S4 Stage II - B7 A4 2.0T K04 - B6 A4 1.8T USP
    USP CLUB MEMBER #95
    Apr 14 2008
    Oceanside, New York
    Well the check engine finally decided to go on, vag'ed it once more and its has all three times been the same low fuel rail presure code. I am not convinced its the fuel pump follower or cam lobe. I know this may sound crazy but my car was in the shop (anchor - which i cannot say anything bad about) and when i told John, my service rep, i asked about the cam follower issue. He told me unless the check engine light was on they do not check it. I cannot believe a week later it happened!!
    John
    BMW M3 ZCP
    Apr 14 2008
    Oceanside, New York
    Dave, i will most certainly keep you posted. In the mean time i would either look into checking your fuel pump lobe or look to upgrade it.
    JD
    BMW M3 ZCP
    Jan 13 2008
    North NJ
    yea, thanks man, I check into upgrading that. I went a little mod crazy over the past few weeks and have to sell some parts before I buy any more lol, but this one sounds necessary
    Previous rides:
    USP CLUB MEMBER #95
    Veteran Member Three Rings jojogoya88's Avatar
    Jan 02 2007
    new york LI
    With all do respect, John is a bullshit artist. Deal with another dealership thats mod friendly. They just want to get money out of you. Good luck with the fix. Usually the outcome when negative things happen is even better than what you had before...maybe youl go stage 17!
    E90 M3!!! Interlagos
    Audi A4 B7 6spd S-Line Titanium Pk. SOLD
    Nov 05 2007
    Oregon
    The problem is that the party line from AoA relayed through dealers is a policy of sticking their heads in the sand on the cam lobe problem, hoping it will go away if they ignore it, hoping owners will be willing to pony up for a new cam and follower down the road out of warranty. What they fail to understand, of course, is even their own history of class action lawsuits, and how this is moving that direction already... As this weak point in this engine gets documented more and more, they're either going to have to come up with a fix, or start covering the part longer than they'd like to. Their preference, right now of course, is not to check it, and that way they won't have the documentation needed for later action. They'd much rather screw the customers of higher mileage cars, continuing to ignore the impact of long term repair costs in owners' minds on their reputation.
    We see you, AoA, and we're documenting your behavior. You'll pay for this in the end. Perhaps you'll stand behind your engineering prowess you like to advertise so highly, and make this problem right!
