Results 1 to 24 of 24
    Veteran Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    installing intake
    I am in the process of installing my x-1 intake and was wondering what I am supposed to do with the sensor like things that are connected to the stock airbox lid.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: installing intake
    The are ECM's and I would mount them in a safe location away from as much heat as you can
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Dec 24 2008
    Milwaukee
    can I just let them dangle somewhere? lol
    Feb 17 2008
    Ottawa Ont.
    your intake should have come with a mounting plate for those sensors that gets screwed into the firewall/shock tower area near the fuel lines.
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Quote Originally Posted by jamestown478 View Post
    IMO No, the wires will move around adn eventualy cause you issue with miss fires ect, mount them, it should only take a few minutes to fab a bracket up or put them on the fire wall with the plate from the airbox,
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Honest question - why did you feel it was necessary to get this intake? Performance, sound?
    Since all my other vehicles have been of the jdm variety, I have to fight every urge I have to install an intake in my S4 as that's usually the first mod done to my 4 bangers.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    IMO. sound will be the only real benefit other than looks under the hood. The stock airbox is a TRUE cold air intake and it is VERY good. the stock filter is also very good if it is changed regularly. There are S4's running 10's and low-mid 11's on stock airbox and filter. I do think some of the aftrmarket stuff is pretty cool, but in a lot of cases they can actually hurt performance. Heat soak etc. I am not saying anything about specific brands as i haven't seen all of them. But until i need to worry about breaking into the 10's, stock aribox for me. But to answer the OP's ?.... Those are ignition modules. do the right thing and anchor them properly. Good luck!
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    Quote Originally Posted by obijohn22 View Post
    +1
    Senior Member Three Rings AK1RA07's Avatar
    Dec 07 2007
    2001 S4, 1992 Miata, 1993 RX-7
    DFW
    Somewhat offtopic, but how are people running upgraded MAF's on stock airbox or RS4 components? If you say just get an RS4 airbox and accordian hose, I thought that was for an 83mm MAF.. how are people stuffing 85/88/90mm MAFs inside a 83mm hole?.. sounds dirty.
    Dec 24 2008
    Milwaukee
    I connected them to the back of the carbon fiber part of the intake till I get the time to permanently mount them
    Dec 24 2008
    Milwaukee
    Quote Originally Posted by CONTROL ONE View Post
    I got it basically for the looks and because I had some extra money laying around. I love the carbon fiber look and how it looks similar to the one on my is300
    Dec 24 2008
    Milwaukee
    do I have to unplug the battery after installing the intake or what is the proper way to reset the computer to recognize it?
    Sep 19 2008
    Toronto, Canada
    Yes, always good to pull the batt. terminal for 15 mins or so. Just make sure you have your radio code handy.
    I'd do a throttlebody adaptation as well, just cause.
    Dec 24 2008
    Milwaukee
    what is a throttle body adaption and am I gonna have to reprogram the radio or something then?
    Sep 19 2008
    Toronto, Canada
    TBA - just put the key in the ignition, turn it on but don't start it. Wait 3 mins. Then start it.
    Whenever you pull the battery, you have to re-enter your radio security code. It should be located in your owners manual as a sticker or written in.
    Dec 24 2008
    Milwaukee
    does it have to be exactly 3 min or can I like put the key in and go take a shower and then come back and start it? lol
    Sep 19 2008
    Toronto, Canada
    Well, it's a min of 3 mins. I wouldn't leave it more than 5 or 10 but I don't see the harm in doing it. Just count backwards from 180.
    Nov 30 2006
    annapolis, maryland
    it should be metal to metal. If i remember correctly that is a way for them to desapate heat. Dont want to have to replace them.
    Nov 30 2006
    annapolis, maryland
    I unplug my battery for months at a time and have never had to reset my radio or anything... you silly kids
    Sep 19 2008
    Toronto, Canada
    Quote Originally Posted by Dr.Duct View Post
    Odd. If mine is disconnected at all, regardless of time, I have to enter the code again.
    Dec 24 2008
    Milwaukee
    I connected them to the metal plate that came with the intake kit. I just temporarely mounted the metal plate against the carbon fiber till I can get a hold of a drill to permanetly mount it
    Dec 24 2008
    Milwaukee
    also I didn't have to reset my radio or anything either.
    Sep 19 2008
    Toronto, Canada
    Stupid car. Maybe it's a Canadian version thing?
    Veteran Member Three Rings wesS4's Avatar
    Nov 29 2007
    1966 Mustang
    San Jose, CA
    Just mounted them to an OEM heatsink like the one on the stock airbox and attached it to the back of the CF
    Stage 2 B5 A4 Avant | AWE | GIAC | H&R | OEM+ | BBS | Raven MS | 034 | DDM
    The Auto Shop
    TEAM|AXION is dead. RIP LOL
