Results 1 to 20 of 20
    Senior Member Three Rings ColinGruenfeld's Avatar
    Oct 24 2006
    Stage III Tiptronic B5 S4
    Colorado
    Stage III here I come
    Hello again guys,
    As I have recently posted, I blew my K03's and am going K04's on my 2000 S4 TIP. Here's a list of everything I plan on purchasing within the next week:
    Aftermarket parts:
    - RS4 K04's
    - K04 Hardware
    - RS4 K04 Inlets
    - Aftermarket Motor Mounts
    - IPT Torque Converter
    - IPT Fully built TIP transmission
    - Stage III- tune from Chris Tapp
    - 2001.5 turbo oil lines
    - Samco TBB
    - Making fully gutted piggies (I'm emissions exempt to I will be completely gutting both pre-cats and post-cats)
    - Snub Mount
    Maintenance parts:
    - Timing belt/water pump kit
    - Spider hose assembly w/ puck valve
    - Power Steering Pump
    - ABS Module repair
    Already have:
    - Bailey's DVs
    - UUC VM1 cat-back
    - eBay Front Mount Intercooler
    - Stage II tune from Chris Tapp (he's willing to cut me a deal on a K04 tune)
    QUESTIONS:
    1. Are there any suggestions for items that I should also be looking into?
    2. The transmission that I am purchasing is out of a 2001.5 S4 TIP, it includes a VAST TCU, but it is not the same TCU model as mine. Will I need to simply swap TCU's, or will I need to reprogram my current TCU? Will anything special need to be done for the tranny swap?
    3. What can I expect to sell the stock tranny for with 103K miles on it?
    4. Any suggestions for this project? I'll be doing it myself in my garage.
    Thanks for your help guys - Odds are I will be relying on you all for assistance throughout this process.
    Audacity - The Nogaro 2000 S4
    STAGE 3 PJ K04's + IPT Tranny/TC + This and that
    Full Stage III TIPTRONIC
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: Stage III here I come
    a 2000 and a 2001 car TCU may not work, Dose the 01 has ESP? if so You may have an issue. from what I have learned a ECU and TCU need to be the same code , for example my car is an 01 and I have a L box ECU and an L box TCU. you may want to talk to the compainy doing your fuel kit and tune to se if the TCU and ECU will work ok, but fiend out if the trans donar car has ESP or not, some early 01,s did not. I just wrapping up a trans fix/rebuild after blowing my TIp trans wile running full stg 3 TQ, If you are not sure of the state of the trans you are buying I may not hurt to have it checked out befor you install it, Also make sure that your TC is good as well if not replace or send it out for a good rebuild/upgrade. Vast or 517 trans I recomend. Also replace your motor/trans/diff mounts Good luck and if you have ? Pm me, I have gone threw the stg 3 tip issues and hope to have resolved them all lol enjoy it and good luck
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    I thought there was no actual proof anything was done with these?
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    Regardless you should install a heatshield of sorts on the passenger side oil line. It runs within 2 inches of the manifold and is what many believe causes the passenger side turbo to fail more often than the drivers. I used a sparkplug boot from Napa.
    Oct 24 2006
    Colorado
    Thats a great suggestion Pauly. One more question for you guys - how hard is it to pull the motor without a lift?
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    I have some turbos for sale if you want them!!
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    Quote Originally Posted by ColinGruenfeld View Post
    how so? I know you don't live in the same state as me but I'd love to know what exempts you
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Oct 24 2006
    Colorado
    Quote Originally Posted by Chknkatsu View Post
    I own a condo in Summit county - which is where my car is registered, which also happens to be an emissions exempt county.
    Oct 24 2006
    Colorado
    Anyone thats done this before - how hard is it to pull the motor without a lift?
    Does anyone think that it IS justifiable to pay a shop $2500 to install turbos?
    Senior Member Two Rings Splinter's Avatar
    Jan 31 2008
    B.C., Canada
    without a lift? i have no idea if it can or can't be done, but i know you can rent them for a decent price, doing that might be your best bet if you don't have a friend that can lend you one. sure is better renting one for ($100? i dunno haha) than paying $2500 for labour imo
    2001 S4 6spd black on black- GIAC, Borla, BBS CH, CarPC, rattle can white trim, 034 snub w/ cage, ebay silicone hoses, AWE DTS, obligatory RS4 grill... dreams of Stage 3...
    2000 Audi A4 1.8TQM - RIP March 9/08
    Registered Member Two Rings
    Oct 28 2007
    PA
    A lift isn't necessary, an engine hoist is though. If its your first motor pull in any car just follow the write up closely, mark all your bolts as you take them out and take your time.
    FS- Giac X Ecu $350shipped
    Oct 24 2006
    Colorado
    Update for ya -
    Day 1 (Saturday) - Beginning
    Day 1 (Saturday) - End
    Day 2 (Sunday) - Beginning
    Day 2 (Sunday) - End
    Day 3 (Monday) - End
    Day 3 (Monday) - Remaining Parts
    Keep in mind, I have an 8-5 Monday through Friday, can't accomplish that much on weekdays.
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Looks like you are moving along nicely.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    How is your project going?
    Oct 24 2006
    Colorado
    Everything is disconnected on the motor/tranny now except for the front half-shafts. We're getting there. Plan on having it all out by tomorrow. Still waiting for the transmission though before everything goes back in.
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Why'd you take the hood off? I never thought of that, lol. It would make for some nice extra room though in the 5 minutes it takes to remove it. Good luck on your install, and make sure you don't have any bolts left at the end!
    Oct 24 2006
    Colorado
    Day 4 (Beginning)
    Day 4 (End)
    Day 5 (DONE)
    Bad driver side turbo
    Creepy Indian Spirit who provided Moral Support
    May 26 2008
    Riverside, CA
    LOooooL that's a creepy indian spirit!!!
    Did you find him peeking out from behind the engine?
    For sale: 2000 S4 Silver, K04, FMIC, Piggies, MBC, SSP tune & Rebuilt TIP.
    Oct 24 2006
    Colorado
    Quote Originally Posted by Caddy7 View Post
    Na, he was hiding in the dead turbo.... bastard was probably the reason why it died. lol.
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Looks like your doing well. Keep up the good work. Hopefully Ill have some pics to post this summer.
