Originally Posted by
chaos2984
560 total thats not that bad to do both valve coer gaskets. If you think its high do it yourself. Alldata says 3 hours a side. you have to remove all coil packs the harness and everything above the covers. And all those bolts in the cover. Thiers like 20 for each one.
It certainly doesn't take 3 hours to perform this job. The only issue i can see the techs running into is removing the lower rearmost valve cover bolts. Other than that it only takes a half hour to remove all of the engine covers, airbox, MAF, coolant tank, coil packs and the valve covers.
If you are mechanically capable id suggest doing it yourself. The valve cover gaskets are $60 tops depending on where you go.
