Results 1 to 8 of 8
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    17x9 +20 offset?
    Anyone running a setup similar to this? I am considering purchasing a set of 5x112 to 5x120 adapters to run my BMWs ASA AR2s that are 17x9 +45. The adapters are 1 inch which brings the offset of the wheels to +20mm. Currently on sport suspension..
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Re: 17x9 +20 offset?
    Those will stick outward 2" more than stock wheels if I'm calculating it right.....
    http://www.1010tires.com/WheelOffsetCalculator.asp stock is 7" wide and 45mm offset, right?
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    This would result in ridiculous wheel poke. For example, with my 18x8.5 with a 35 offset, I am already right at the fenders. I cant imagine how a 9" with 20 offset would look
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by biketsai View Post
    LOL it will have 9mm more clearance on the inside and stick out 21mm more.
    I hope you're going widebody b5andm3!
    because racecar.
    May 22 2008
    St Clair Shores, MI
    I have 8 1/2" with et 30 and they stick out a little bit already.
    13 S4 Monsoon Gray - 6MT l sports diff l Nappa l Atlas l EPL Stg2
    DP l MercRacing HX l iAbed TB l Sach's Xtend l AWE Track/Touring w/ res DPs l 034 Xbrace & drivetrain mounts l P3 Track
    Aug 22 2008
    Central Maryland
    Quote Originally Posted by Kyle H View Post
    howd u know. rs4 fenders
    Senior Member Three Rings ForceFed's Avatar
    Dec 30 2008
    minnesota
    eating up wheelbearingS like mad man
    NOM NOM NOM
    01 Silver s4. BASIC BITCH
    04 Ultra Sport black on black 1.8t 6spd Avant
    00 s4 6spd dp's, magnaflow twin 2.25in,k04, j-fonz ,pss9's,hotchkiss sways,19vmrSOLD
    sold98 a4 1.8t quattro 5spd, some mods...GT2860elim,unitronics tune, 415cc injectors(green top), 3in vr6 maf, carbonio intake,2.5in exhaust, bilstien pss9's, 18in OZs, EVOMS intercooler 2.5in piping ect..
    sold91 ford sho white on black, modded
    Feb 23 2004
    audi, vw, 72 bronco
    ne, pa
    -this past year i had 18 x 8.5 et 45 wheels with a 25 spacer and it only poked about 6mm.(rear)
    -tire choice would definitely be key in this situation. i think they would work all depending on how low you are also(poke of course)
    -fronts are probably going to give you a little issue.
