    Veteran Member Four Rings LowA4's Avatar
    Aug 04 2007
    00 S4, 01 Allroad
    Gardnerville, Nv.
    No cruise control fuse
    I was just looking at the fuse box and the # 11 fuse slot is empty, not even any prongs inside to hold a fuse, just an empty slow. Any ideas on why?
    C5 RS6
    Stage 3 b5 S4
    8P A3 quattro
    B6 usp A4
    C5 Allroad
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Re: No cruise control fuse
    get A VAG COM AND RECODE IT THATS WHAT WAS WRONG WITH MINE SO SIMPLE MABY U HAVE A SIMILAR PROBLEM
    Established Member Two Rings asc_up's Avatar
    Feb 01 2010
    Tacoma, WA
    Bump.
    I also have the same issue.
    Will I be able to switch modes with an APR ECU even though I don't have a working cruise control?
    Aug 06 2008
    Canadia
    my CC dosn't work, i remember seeing the code about short to ground for CC speed sensor once.
    the B5 S4 is like the mafia... there is only one way out!
    Jan 29 2007
    08 S4 00 S4
    MD
    I'm almost positive the cruise control circuit is tied to the tail light fuse on manual transmissions.
    08 S4- Stock SOLD
