Results 1 to 9 of 9
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    Boost Gauge Problem
    I installed a VMR vent boost gauge about three weeks ago. Today when I started my car the bottom of the gauge didn't light up. The top however was fine so its not a bad connection with my headlight switch. After a couple of minutes it came back on and was fine after that. It did this every time I started my car today and every time came back on after a couple of minutes. Is it just a bad led? Has anyone else had issues with VMR's gauges?
    Stretched, poked, and slammed.
    Jun 08 2008
    Calgary AB Canada
    Re: Boost Gauge Problem
    my vmr is slightly brighter at the top than at the bottom. ive stopped caring though
    Oct 07 2008
    Lancaster, PA
    Sounds like it might be a manufacturing defect in the gauge having to do with a faulty connection. I might give VMR a call tomorrow and see what they can do for me. This shouldn't happen within three weeks of install.
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    How were you able to remove the wiring harness from the vents? I know it seems like a n00b question, but the yellow connector on mine refuses to come off.
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
    Jun 01 2008
    San Diego, CA
    bump
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    Quote Originally Posted by GermanAudi View Post
    just pull away from the vent the holding onto the yellow connector.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Jun 01 2008
    San Diego, CA
    I pulled and the yellow connector is still firmly connected, refusing to budge.
    Oct 07 2008
    Lancaster, PA
    If I remember right I believe I just pulled it off. I don't remember any clips or anything. Good luck.
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Quote Originally Posted by onceover View Post
    mine dont even have a light...lol
