Results 1 to 19 of 19
Thread: HIDs for $40
    Veteran Member Three Rings oldblu's Avatar
    Jan 01 2008
    Budd Lake, NJ
    HIDs for $40
    I want to buy this set up for my fogs (S4). Should I? Can I? And is the set up pretty easy?
    Go down the page, they are the Raptors that are temporarily out of stock.
    Click ME
    --Silver 2000 A4 2.8L V6 Quattro
    S4 Bumper. Borbet Type LS Wheels. M3 Replica Spoiler
    Blue! How come there's no ice
    in my lemonade?
    Registered Member Two Rings Sick_Boy's Avatar
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    Re: HIDs for $40
    ill be picking up a set for my fogs when they get 'em in. just go with the 35w if your gunna use them in your fogs.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: HIDs for $40
    Setup is the same as it would be for a headlight.. I would say go for it, but keep it to the same color as your hid's or do a yellow setup reflects water ect better on the road.. But that is just me.. Would look good though since hid headlights and dull fogs dont look so good.
    Veteran Member Three Rings Robb12's Avatar
    Aug 04 2008
    Orange County
    Re: HIDs for $40
    How long does the sale run til? I would like to pick up some 3000k for my fogs but I need to wait til my next paycheck
    Dec 05 2007
    Re: HIDs for $40
    Notice: As of January 23rd 1:20pm Raptor kits come standard with 1-Year warranty. All orders placed before 1/23/2009 will still have life-time warranty.
    Even VVME has a 2 year warranty. Is there a reason they needed to change the warranty product on this model of HID kit? Maybe too many claims and they felt it not benefitial on thier behalf to offer a lifetime warranty on a product that is known for crapping out (assumptions, but just makes logical sense). If you want to go for it, I say go for it. But you could also get the Apexcone ones listed right above it for $55 (basically, $15 for lifetime warranty is worth it; $7.50 per ballast/bulb).
    Oct 06 2004
    Minnesota
    Re: HIDs for $40
    I have actually heard good things about chinese made xenon kits.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Re: HIDs for $40
    Dumb question I'm sure but which bulb would you get if you want them for your headlights?
    Nevermind my car has factory HID's I believe? Can I just replace the bulbs for different colored bulbs?
    Dec 05 2007
    Re: HIDs for $40
    Not a dumb question (I don't flame people ). Our cars have H7 in the low beam, high beam, and fog light.
    Edit for above: You need to find out if you indeed have HID/Xenon's in your stock headlamps before ordering. Then you need to find out if the bulbs for that kit are H7 or d2s. And you can replace the bulb with whatever temp you want, but make sure you get the correct bulb size.
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Re: HIDs for $40
    so if i were going to run these in my headlights i should get the 55w ones? but it says it will wash the color out so do i need to get the 6000k or what color is the brightest?
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Dec 05 2007
    Re: HIDs for $40
    ^I myself run with a 55w 5000k kit (Retro-Solution). People say that 4300-6000k range is the ones to get for the best light output. My 5000k bulbs are like a perfect white.
    Jan 01 2008
    Budd Lake, NJ
    Re: HIDs for $40
    Quote Originally Posted by njm23 View Post
    What do you mean about the color? When I get HIDs, I'm gonna get 6000K. If I wanted a different color, I'd go for a slight yellow.
    in my lemonade?
    Dec 08 2006
    Cincinnati
    Re: HIDs for $40
    Its probably good you don't flame! Our cars have H7 in high and fog, d2s in low beam (he said he has factory HID). If he did not have HIDs, then your H7 claim would be right however.
    Dec 05 2007
    Re: HIDs for $40
    ^He edited that in. It was not in his original inquiry .
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Re: HIDs for $40
    Indeed I edited after my brains began to run again
    Feb 28 2007
    04 a4 USP ; ATS
    Re: HIDs for $40
    Quote Originally Posted by oldblu View Post
    I just meant if you run HID lows, and want to run fogs it would be wise to get upgraded fogs since the car looks kinda dumb with hid headlights and the stock halogen fogs.. Colors are so different. Just personal preference and I have heard that the yellow (i guess 3k) reflect the ground a lot better with ice/water ect.. so they are very useful and look good.
    Oct 06 2004
    Minnesota
    Re: HIDs for $40
    3K is pretty cool. I would run them for my high beams if they didn't attract cops
    Instagram r_michals
    Jan 01 2008
    Budd Lake, NJ
    Re: HIDs for $40
    Ok. Just ordered 6000k. Total: $50 Can't wait
    in my lemonade?
    97 A4 2.0TQM
    Rochester, NY
    Re: HIDs for $40
    Quote Originally Posted by A4Rob View Post
    A friend of mine has an extra set of H7 3000k that I was going to try. I took a look in the new york vehicle laws and didn't see anything about bulb colors .. so I might try them.
    edit:
    did some more reading and apparently it does state "white light" oh well.
    Jan 19 2008
    Re: HIDs for $40
    Quote Originally Posted by pac1085 View Post
    edit:
    It should be fine. Have you ever seen an older Lexus GS, ES or IS in New York with its fogs on?
