Results 1 to 35 of 35
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Another update. This time the exhaust manifold's welds are completed...
    The unit is test fitted to my car and we show that a hood clearance issue is a non issue.
    First three different angles of the exhaust manifold with all welds done.
    Angle one :
    Angle two :
    Angle three :
    Test fitted in the car.
    Close up.
    Turbo clearance with hood. You can tell the turbo sits below the top part of the valve cover.
    From further away with a different angle.
    Still further away.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Another update. This time the exhaust manifold's welds are completed...
    That is some sweet welding done on the manifold.
    One question though... where is the wastegate merge?
    Jan 04 2009
    2004 A4
    Las Vegas
    WOW!!!! great job! that looks amazing.
    Jun 17 2004
    Montreal, Canada.
    It's the next step along with the DP.
    Now that the actual manifold portion is done he can work on the WG and DP solution.
    Jun 11 2005
    Vancouver, BC
    Well that make too much sense
    Do you have any pictures of the collector?
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    I love seeing these pics - it's inspiring to see someone building their dream.
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    Veteran Member Three Rings JayStang's Avatar
    Jun 23 2008
    2008 Audi A4 S-Line Ti 2.0T
    Boston, MA
    wow looks amazing. wish i could weld half as good!
    Veteran Member Two Rings
    Mar 15 2004
    Is the compressor housing touching one of the runners?
    2001.5 A4 1.8tqms
    Pectel SQ6 ECU
    2.0 built motor w/ AEB head
    GT3071r w/ Full-Race Manifold
    725cc Injector Dynamics
    Startup Racing Contest Suspension 600/700
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    That is beautiful! Can't wait to see it perform!!
    02 A4 3.0Q6MT
    -chad
    Jun 11 2005
    Vancouver, BC
    Quote Originally Posted by Enclave View Post
    If the fabricator built that manifold piece by piece with the turbo in hand I don't see how that would ever happen
    Senior Member Three Rings Kengineer021.8's Avatar
    Sep 26 2006
    Whittier, CA
    I love Jet Jockey threads!!!
    Go: APR Stage 2, TT 225's, Forge 007 DV, STaSIS SS, RS4 Rear Sway, RaceTec FMIC, Forge TIP
    Show: 19" GM VMR 708's, Delsa S4 Spoiler, Blacked Out Grilles, Tint, Smoked Side Markers, De-Badged, RS4 Engine Cover, Aero Wipers, RNS-E, CC, Tinted Tails
    Jun 30 2007
    Raleigh, NC
    absoultely fucking sexy.
    ...i know this is weird - but i have to ask if you can will your manifold to me
    you know, just in case.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Jet Jockey View Post
    I understand the DP solution, but the WG should be a part of the manifold? If I were making a manifold I would figure out the WG route before I did the whole thing but I guess thats why I dont make manifolds
    - Clint
    Jun 17 2004
    Montreal, Canada.
    It will be part of the manifold. It will be installed in the collector. So I guess technically the manifold is not 100% finished yet.
    We still need to install the four bungs for the EGT sensors and one for the A/F ratio sensor.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Not much to figure out, my guess is the WG will end up in the same spot as were it sits on the Full-race manifold, plus this is a race car so Mike will most likely just run an open dump since that helps reduce back pressure in the down pipe. Only difference on Mikes manifold vs the Full-race manifold is that it has a vband and the higher angle of the collector tubes.
    Veteran Member Four Rings turbo kraut's Avatar
    Oct 30 2006
    09 pontiac vibe
    StL, Missouri
    looks that way, but probably partly to do with the angle of the pic
    2001 Honda CBR929RR - modded - mine
    1992 Ford Bronco - The Beast - mine
    2009 Pontiac Vibe - stock - wifes
    1981 Suzuki GS1100 - sold
    2011 Ninja 650r - sold
    2001 Audi A4 - totaled 3/31/13
    2006 Honda CBR600RR - traded
    1982 Honda GL500 - sold
    2011 Ninja 250r - sold
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Run the OEM air box :D
    Jan 25 2006
    A4 2.0T
    MD
    Bung for the wideband in the exhaust manifold???
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by Don Supreme View Post
    I guess you did not understand or perhaps I used the wrong words...
    One EGT bung in each exhaust manifold runner (~1" from the head).
    One A/F sensor 18" down on the downpipe.
    Veteran Member Four Rings aLeXliu911's Avatar
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    very beautiful piece of art, i have to get one of those.
    BetaAlphaTau member #11
    2003 A4 1.8T 5SpdMQ Black
    545awhp, 477.4awtq
    Stasis Motorsport C/O
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Status Carbon Fiber Seats. ER Comp FMIC
    2008cc, AWM, Ported AEB Head, HTA GT3582R,Full Race Exhaust Manifold, INE Intake Manifold
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    What is the weight of the car down to and what is the estimated power you foresee with this set up?
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    That is looking awesome Mike!
    -Doug
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by sambrody44 View Post
    I really, really hope that the car's weight when finished will be around 2900 lbs.
    We are going with a very conservative tune of 400 CHP on 93 octane and 470-480 CHP on MS109. Reliability, longevity and a smooth power band are the priority here.
    However once we get it on the engine dyno maybe we will be able to get more out of it. Don't forget my previous set up was probably around 300 CHP maybe a bit more with race gas.
    Now this set up would increase the cars' power by 100 HP on 93 octane to maybe 175 HP on race gas and the car was stinky fast on the track already.
    On top of the launch control and several gas files I'm working on getting a "pass button/file" installed. By deperessing a button on the steering wheel the SM4 would go into a "passing mode" giving me extra HP for passing another car on the track. Now that could be cool.
    Dec 12 2006
    Charlotte,NC
    I must say your build is badass. If i had the money i would do the same. Looking forward to see how this turns out.
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Whats the ET on maybe getting some speedo shits?
    -Sami-
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Sorry Clint, nobody is going to buy your manifolds...
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    HAHAHA. Tell me someone actually tried to use that!
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Sep 26 2006
    Whittier, CA
    I wish I could see what the inside of that monstrosity looked like... those horrific welds probably decreased the id by about 50% haha
    Jul 07 2004
    socal
    You could do that just with a EBC giving it a set bump in boost for a period of time.
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by actlsub9 View Post
    i now feel infinitely better about my welding skills compared to...... that....
    thanks for the esteem boost greg
    buy my turbo!
    The Awesome™
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Wow, another serious component into the most gnarly ride on the forums.
    Salut, sir.
    That's cool, but would you have to hold and adjust the EBC or could you relay it to work through a switch?
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Jul 07 2004
    socal
    Quote Originally Posted by Tactic12 View Post
    Salut, sir.
    Some have what is called a "scramble" mode. This causes the EBC to add an amount of boost that you set it for and for a set amount of time you set it for. So you can either hit the button and it goes back to normal boost after a set time period or you just hold the button and release it when you want the boost to go back to normal.
    Basically its just a ground input on the wire harness of the EBC that has this mode.
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    The AVC-R has a built in function called scramble boost that increases the boost for a set amount of time. You just need to install a switch and set the amount of boost you want and how long you want the increase.
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    very nice mike
    Some fast things and some slow things
    ~Josh~
    Veteran Member Four Rings audi til I die's Avatar
    Mar 04 2008
    IL
    Great job OP! When do you plan on finishing this bad boy?
