Results 1 to 10 of 10
    Established Member Two Rings audicarnut's Avatar
    Dec 09 2008
    1985 VW Golf TD, 1988 VW Scirocco 16V, 1999 Porsche 911 Carrera, 2011 VW Touareg VR6, 1995.5 Audi S6
    Tipp City, OH
    Transmission Fluid
    I was planning on changing my transmission fluid, but I'm not sure what I am going to put in it. I have an 01 s4 tiptronic. I want to put a synthetic fluid in, any suggestions (brand/type/weight)?
    Senior Member Two Rings curlyfrieS4's Avatar
    Nov 19 2008
    S4 Twiny Terbs
    San Diego
    Re: Transmission Fluid
    I surely would like to know aswell
    Sold: 2000 S4 Stage II: 17' BBS RGRs. GIAC X. JHM FMIC. Piggie pipes. 710n's. RS4 clutch & flywheel. BORLA Cat Back. UUC Short Shifter. Stasis Coilovers. Need Brembo brake kit!!!!!!!
    Current: 2001 Audi S4. Stock :)
    Aug 06 2008
    Canadia
    if you flush out all the fluid you can use Mercon/dextron 3. the audi fluid is essentially the same stuff only semi synthetic and with an additive to make it not backward computable if its mixed.
    if thats a little too daring for you, you can use valvoline maxlife ATF, its compatible with the audi fluid and substantially cheaper than OEM.
    just make sure you replace the filter too, the new fluid can end up picking up old friction material the old saturated fluid could not and plug the filter with it. Some people recommend against changing the transmission fluid if the fluid has been in the transmission for a long time (such as the case in a B5 s4 tip) but changing the filter can avoid any issues.
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    from what I was told and have learned OEM fluid is the one to use, but others have had sucess with other brands like mentioned above, the Shop that rebuilt my trans told me to fill it with OEM stuff. Also replace teh filter as well when ever you change the fluid.
    fo rexample blauparts.com sell a kit
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Dec 09 2008
    Tipp City, OH
    Is there a pump that is necessary for putting the new transmission fluid in?
    Veteran Member Three Rings chrisbostonusmc's Avatar
    Jan 12 2008
    Sarasota,Fl
    Quote Originally Posted by MacDaddy View Post
    I did this on a BMW step-tronic and replaced the filter as well and the tranny shit the bed 10k after
    Stage 3 SSP Tuned RS4 K04'd
    12.4 @ 115 on pump gas only
    425AWHP/467AWTQ
    ALL MY MODS DONT FIT IN SIG! DAMMNITTT!
    95 Toyota Supra T51R 800hp
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    if you change it regularly 20-30k then you do not have to worry.
    if you do not there is so much friction material from the clutch packs in the fluid thats the only reason that your auto works still, so if you have no idea if its ever been changed, check it to see if you can tell if its brown colored. if it is dont change it cus it will happen as stated above by: chrisbostonusmc
    Aug 06 2008
    Canadia
    Quote Originally Posted by chrisbostonusmc View Post
    if a transmission is fucked, all the AT fluid in the world can't save it.
    Aug 30 2007
    nyc
    don't change it best advice your gonna get........
    c5 A6 tip
    this n that
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    What effect would the wrong ATF level cause?
