Results 1 to 10 of 10
    Veteran Member Three Rings chrisbostonusmc's Avatar
    Jan 12 2008
    Sarasota,Fl
    Weird Southbend Stage 2 Clutch Issue.
    Got my clutch installed by Absolute Automotive(sponsor here) so I know install isnt an issue.
    I was driving my wife and I to Red Lobster and all the gears in the car started to slip. I have been breaking in the clutch fine too(i havent been in boost), I freaked out, when in to eat dinner(well I couldnt eat) then I came out halfway through dinner and couldnt even shift any of the gears into place.
    After dinner it ran fine but i felt some shudder type of skipping in the clutch pedal when releasing my foot. I also smelled the infamous burning smell
    Waited an hour took it out again, ran fine again, no slippage, put it in 5th around 30mph floored it and got no slippage.
    Downshifted to second and it held it fine
    I dont understand why this is happening.
    Waited another hour drove it normal and went back home and everything was okay but still got the burning smell.
    Help please..theres only 1k on this clutch and its a month old
    Stage 3 SSP Tuned RS4 K04'd
    12.4 @ 115 on pump gas only
    425AWHP/467AWTQ
    ALL MY MODS DONT FIT IN SIG! DAMMNITTT!
    95 Toyota Supra T51R 800hp
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Re: Weird Southbend Stage 2 Clutch Issue.
    Try going back to absolute and get them to check it out you never know, that would be the first thing i did.
    2010 Brilliant Black/Magma Red S4
    Jan 12 2008
    Sarasota,Fl
    That is the plan for now, I want to have it reput back on the dyno at Absolute because the last two times I drove it, the car didnt feel as strong
    has anyone had this issue before?
    425AWHP/467AWTQ
    Jul 26 2008
    Jersey
    I think it's something related to heat. It seems that when you let the car cool down the issue doesn't persist.
    Maybe a PP/FW issue? pretty odd..
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Did you make sure SAC (self adjusting clutch mechanism) was set? This could cause your clutch to wear out really fast depending how bad it's off.
    -02 F'in Silver. GT2560/s AWE, ER/s RS3 Wheels, KW/s and every other typical S4 upgrade.
    Jan 12 2008
    Sarasota,Fl
    Quote Originally Posted by spinny View Post
    Its the A.W.E. stage II kit and comes with an rs4 pressure plate. Absolute resurfaced the flywheel as well..
    Quote Originally Posted by GetAwayFromMe View Post
    I really hope not, now that you mentioned this.. im guessing it could be the suspect since its only been about 1100 miles since it was installed (800 highway)
    any way this could be a slave cylinder issue?
    425AWHP/467AWTQ
    Jan 03 2008
    Iowa
    No im afraid not. Slave will not make the clutch slip but would stop it from being able to shift. When i got my clutch from VAST it was a lil off what helped was that they marked it when they adjusted the SAC so i just readjusted it.
    It can happen if they throw it around at UPS or who ever shipped it. I know this sucks man and what sucks the most is that you will need to pull the tranny again and buy a new clutch if this is the issue.
    Jan 12 2008
    Sarasota,Fl
    well Southbend has a 1 year warranty on their clutches so we'll see how this goes..What is weird is the one time it wouldnt go in gear (made me think my tranny was shot) but after the car cool down everything was a okay
    Im calling Southbend in the morning..
    425AWHP/467AWTQ
    Jan 03 2008
    Iowa
    Quote Originally Posted by chrisbostonusmc View Post
    Maybe you got lucky and the SAC set itself and you are all good now Either way good luck man!
    Jan 12 2008
    Sarasota,Fl
    we will see I am driving home from FL today
    425AWHP/467AWTQ
