Results 1 to 24 of 24
    Veteran Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    Push Button Start?
    Well I got bored very easily so I decided I would start a new project. I want to install a push button start in my car. First question, has anyone done this before in the A4? What is involved, is it reasonably possible, and what would the difficulty level of this be?
    Thanks
    Cameron
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Oct 27 2008
    Montgomery TX
    Re: Push Button Start?
    Well I just looked this up.
    It seems simple enough on a Honda. hehe
    So I would need both an ignition switch and a momentary push button starter. Hmm what if my friends decided to be a dumbass and pushed the button while the engine was already running? Would it still turn the starter? From what I've heard that's very bad
    Stage 2+
    Oct 27 2008
    Montgomery TX
    Actually another way I just thought about is to jus put the keys into the ignition, turn them to the run position and have a momentary push button that is wired to power and ground and have it run to the starter. that seems like the most practical way.
    Stage 2+
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    idk what to think of this, imo sounds like a waste of $
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    The most practical way would be to turn your key all the way. Don't do stuff to your car just for the sake of having something done. You will regret it in the long run. Not to mention you will get flamed like hell in the short run.
    Stretched, poked, and slammed.
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    I did it in my car because I took my car apart.
    The Honda S2000 button is something like $100 in Canada and the Audi push to start switch is something like $400... LOL.
    Needless to say I bought an el cheapo switch and it works fine.
    Sep 13 2008
    Western Chicago Burbs
    i think it is only cool if you have keyless go or something like that. i don't see the point of it if you still have to put the key in. are you trying to impress the ladies?
    Oct 27 2008
    Montgomery TX
    I'm just going to do it for pure show and looks. I'm going to do it the easy way, just power the switch and run it to the starter, so you have to turn the key to the run position then pres the button. I think it will be relatively simple. I'm going to go look for a good place to put the button. I'm getting the S2000 button for $15
    Stage 2+
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by B6JoeA4 View Post
    I don't have a key either!
    Jun 08 2008
    Calgary AB Canada
    youre going to need the key no matter what because of the immobilizer chip and steering wheel lock.
    that thread with the rs4 button looks pretty good though
    Oct 27 2008
    Montgomery TX
    Okay I decided I'm going to try andd it the right way,... like this...
    http://www.youtube.com/watch?v=o4KCe0l1ppc
    I will be doing lots of research tonight, and if anyone has a wiring diagram of the ignition please post.
    Thanks
    I will keep everyone posted on my progress.
    In the mean time could you'll brainstorm abut where I should have the two switches, one master on off switch for ignition and etc. and the other button for the starter. was thinking mount ontop of the ash tray panel, or in the ash tray.
    WDYT
    Stage 2+
    Jun 08 2008
    Calgary AB Canada
    that will make your car ridiculously easy to steal, and you'll have to disable the steering wheel lock aswell....
    + our cars have an immobilizer chip which will probably make it a bitch to work around
    Oct 27 2008
    Montgomery TX
    wtf is a immobilizer chip? it sounds like it's out of a startrek movie or something
    Stage 2+
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    chip inside of the car that talks to the chip inside your key when you put it in the ignition so that the car is allowed to start up without thinking that it is being jacked
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    If you don't know how shit works don't fuck around with it
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Oct 27 2008
    Montgomery TX
    that's how you learn :D
    Stage 2+
    CO
    I don't really have an opinion either way on this one, but something I don't get is why everyone his giving this guy so much flack about doing something (at least somewhat) functional, yet everyone is on board with putting non-functional shark fin antennas on their cars. I just don't get it.
    I understand the security implications here or even the reprecussions of F'n up the starter, ignition, etc.
    Agreed. I would, however, do a fairly extensive amount of research before starting this project.
    Quartz Gray '11 S4 Prestige || Sprint Blue '06 S4 Saloon - Sold || Denim Blue '02 A4 1.8T - Total Loss || Laser Red '98.5 A4 1.8T - Sold
    Deactivated Four Rings
    Sep 30 2008
    n/a
    my cousin has one in his hemi it goes where the cig lighter was but its stupid because u still need to put the key in and turn and then hit the bottun for it to start
    Jun 17 2004
    Montreal, Canada.
    There is no way around not using a key to start this car.
    If he is still going to use the key to start the car then he is fine. The push to start can be done and it is only a "cool" factor.
    If on the other hand he wants to eliminate the key completely then he needs to get the immobilizer disabled by someone that knows how to do it.
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    immobilizer can be taken care of by APR or UNI, maybe Revo, but not GIAC.
    others can do it aswell
    Veteran Member Four Rings jriddle11's Avatar
    Mar 26 2007
    B7 3.2Q and C7 A6
    Byers Audi - OH
    I love the push button, but only if I can leave my key in my pocket all the time. In my brothers 3 series he has to put the key in the ignition before he pushed the start button. BMW makes the "comfort access" keyless entry and keyless start a $500 option.
    Audi Brand Specialist / Social Media Manager / Spokesperson Byers Imports (Audi, VW, Porsche, Subaru)
    Current: B7 OEM+ and C7 OEM
    Previous: B5, B6, B6 USP All OEM+
    Aug 10 2008
    UK
    A few people have done it in the UK - both B6's and 8P's. Here's a write up from the 8P, all I could find:-
    http://audiretrofit.googlepages.com/...rs4startbutton
    Veteran Member Three Rings kpatz's Avatar
    Nov 08 2006
    '02 Audi A4 B6, '06 Mazda6 wgn
    NH
    Well, if you're really ambitious (and daring), you could dismantle the key fob and the ignition switch assembly, mount the immobilizer chip capsule near the reader coil, and rewire the accessory, ignition, and starter to switches. Then you can do a keyless "airplane-like" startup... master, fuel, ignition, crank 'er up!
    The issue of course would be security... anyone could jump in and drive off without a key. Maybe wire in a keypad security system... enter a PIN, hit the button, and VROOM! Or use a bank of switches where certain ones have to be on and certain ones off in order for the car to start. Eight of them would be 256 combinations, which would slow down a joyrider. Make it so the starter button works with the wrong combinations, so they have to crank the engine to see if it'll start. The repeated crank attempts might get someone's attention.
    2002 A4 1.8T Quattro, 5 Speed, Goodwood Green (rare color!)
    Current mods: APR Stage 1+, TT225, 710N, APR Snub, JH solid short-throw shifter, JH solid linkage upgrade, Sachs clutch, Euro shift knob/boot, 4300K HID D2S, 18" VMR RS4 reps w/General Exclaim UHP, hardwired Valentine 1 w/remote display
