Results 1 to 39 of 39
    Apr 22 2007
    Riverbank, Ca
    MAF went out again...
    So my MAF went out again, in a month... (a week after I could return it... lovely..)
    Its driving OK, not as bad as before, Its definately noticable, but its throwing codes.
    There is no way it got that dirty that quick, I've been driving very normal and I have not cleaned my KNN air filter since my turbo change, so it shouldnt be over oiled (I've been oiling KNN's for 5 years, Less is more. I know)
    Do I just have 2 bad MAF's or could there be another problem?
    Dec 05 2007
    Re: MAF went out again...
    CRC MAF Cleaner and get rid of that K&N.
    Apr 22 2007
    Riverbank, Ca
    I just cleaned it a month ago...
    I cant get rid of the KNN, Im stage 3. I'll just run it dry and clean it every 3 months
    Dec 05 2007
    Do you still have the stock airbox? And it is not just the oil that gets onto the MAF. But any debris that gets past the fibers of the filter will end up sticking to the oil on the MAF (so, you will have oil+debris on your MAF).
    Log the MAF in block 003 to check if the MAF is good or not.
    Senior Member Three Rings eurotecknik's Avatar
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    What should be the normal readings indicating MAF is OK on block 003?
    01 A4 1.8T Quattro Manual - SOLD
    90 Audi 90 Quattro Manual - SOLD
    03 A4 1.8T Quattro Manual - SOLD
    B5 S4 Daily Driver - SOLD
    Current:
    06 A4 Quattro Auto
    Dec 05 2007
    160-180 g/s at 100% throttle
    Oct 06 2004
    Minnesota
    Why not just run a paper filter? K&N filters suck. I bet a paper filter will out-perform a dry K&N.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Apr 22 2007
    Riverbank, Ca
    Yes, with the KNN filter. but its not erm... stock anymore.
    And I dont have vagcom.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Depends on the MAF and MAF housing combo. Some people see as high as 200 g/s with a TT225 housing.
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    So, readings should be no less than 160 g/s? I have a VR6 MAF.
    Current:
    06 A4 Quattro Auto
    Dec 05 2007
    Quote Originally Posted by andyrew View Post
    AZ is full of helpfull people and if you post in the classified I am sure someone will be willing to assist in logging your MAF. If you were nearby to me, I would let you use my VAG com. You may want to also look into the Amsoil direct fitment air filters for our stock airboxes. http://www.amsoil.com/storefront/eaa.aspx
    To eurotecknik, I would assume so. But I am no expert. Maybe GetBoosted84 can confirm?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    It is not the filter that is the problem. Something is causing the maf sensor to blow out and a bad/loose wire tends to be the problem. Also have to figure in that his stage 3 is always pushing the maf sensor to its limits and this too will cause a maf to go bad.
    Apr 22 2007
    Riverbank, Ca
    Mike, so do you think I should run a bigger MAF?
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    most definitely if you are stage III and having MAF problems...
    Dec 14 2006
    Halifax, NS, Canada
    the oil is the main part of a k&n that make it a filter... get a different brand if you want to run a dry one
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Jul 07 2004
    socal
    Well that might be tuff seeing that APR rescalled the readings from the maf, so you really cant just throw a larger maf housing in there.
    First place I would start checking is the maf harness.
    Apr 22 2007
    Riverbank, Ca
    Mike, I assume checking the harness for tears or breaks of some sort? I did that quickly when I first got the code, I didnt notice anything with my naked eye. Do I need to check things with an OHM meter or something?
    Is there a stronger MAF than the factory one that is still 2 7/8"? Doubt it..
    Veteran Member Two Rings
    Sep 01 2004
    San Ramon, CA
    Like Mike said check the harness, I had the same problem and thought I had a bad MAF according to the codes I pulled. Replaced the MAF and still had the same problems, car ran but was sputtering. Someone on here suggested that I check the harness and they were right, 1 of the 4 wires in the connector was barely hanging on and was not giving a good signal. Replaced the wire and the car was good to go, hopefully your problem is the wire and not a bad MAF again.
    Marc
    Established Member Two Rings mnsirtee's Avatar
    Aug 19 2007
    los angeles
    Try getting a bigger heat shield or something better.
    Apr 22 2007
    Riverbank, Ca
    I have the biggest and best heat shield. MAF never gets over ambient temp.
    Im going to check the internal connections on the MAF and clean the MAF to see if that was the issue. If so I'll clean my air filter as it's been a while.
    I bought my last MAF used, but it looked in perfect condition... Maybe I just need to buy a new one and be done with it.
    Apr 22 2007
    Riverbank, Ca
    So, buying a new one... Does the one for the later years work?
    Example
    http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
    Or do I need to go with this
    Anyone used this knock off?
    Yes, Im cheap. Especially if im just going to blow it out in another 3 months.
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    how do you know its the MAF? and what codes are you getting?
    Apr 22 2007
    Riverbank, Ca
    "MAF input sensor low/ out of range"
    Comes back on every time I clear it. (I dont have VAG, just a code checker)
    Same stumbling issues last time I replaced my MAF.
    Feb 13 2007
    98 A4
    Chicago
    I was getting some misfire issues back when I was running the stage III kit that eventually got traced back to the MAF. After numerous spark plugs and coil packs, I finally purchased a brand new older style AEB MAF ($$$) and problem solved.
    Apr 22 2007
    Riverbank, Ca
    Ok, im buying the one for my model year.
    $78 new shipped with 2 month warranty...
    Im throwing on meth and turning up the boost. Lets see THIS one fail in a month...:)
    Veteran Member Three Rings kevin12's Avatar
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Just wondering where you're getting it from for that cheap cause I need a new one as well. I know mines different cause its an 01 too just thought might be cheaper
    Thanks
    Current:
    17 Ibis White A3 2.0TQ S-Line
    01.5 Santorin Blue A4 1.8TQ 5-Speed
    Uni 1+, XS Power Exhaust, ST Coilovers, Forge DV
    99.5 Laser Red A4 2.8Q Tip Totaled RIP
    01.5 Casa White A4 1.8TQ Tip Current Parts Car
    08 Ibis White A4 2.0TQ Tip S-Line
    Apr 22 2007
    Riverbank, Ca
    See my ebay links above in the thread.. There is one for the early models (mine) and a cheaper model for the later one's (yours).
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Yeahhh I saw them and they were cheap just didn't know if there was another place you were ordering them other then ebay... thanks though
    Current:
    Jul 07 2004
    socal
    Is the car going to be ready in time for the 034 open house?
    Apr 22 2007
    Riverbank, Ca
    Its going on the dyno...
    If I have to buy a MAF from 034 I will. But it shipped from Georgia last friday.
    Im going to throw my 15's back on for the dyno :). My 18's and 16's are heavy mofo's...
    Jul 07 2004
    socal
    Cool. Well I guess I will see you there.
    Sep 16 2008
    Tools
    Rochester, NY
    just a quick question. That ebay listing claims that the maf will fit 96-99 VW jettas.. Does that mean that older style 1.8t AEB MAF sensors are the same as the 2.0l ABA MK3 jettas sensors?
    The plugs are identical
    Apr 22 2007
    Riverbank, Ca
    I pulled the last MAF that I had in there for a month from a 2.0. Same part #.
    Jul 07 2004
    socal
    You guys are running # 037906461C ?
    Sep 16 2008
    Tools
    Rochester, NY
    thats a bosch part # correct?
    Jul 07 2004
    socal
    Not sure, that is the part number listed on Purems and one of the parts that Andrew linked to on Ebay.
    Apr 22 2007
    Riverbank, Ca
    New maf went in.
    Seems to be 10x worse. I get a HUGE stumble, It seems like ther is a 1/2 second lag and when I finally DID get it on full throttle (to see where it was at) it sounded like detonation.
    Driving around is OK, better cruise and up to about 1/8 throttle, but there is a stumble still, and after that it seems to be just worse...
    The new MAF has a completely different sensor (wires instead of a circuit board) Part number is correct though.
    What do you guys think, MAF or other? The only other thing I did was clean my air filter and re-oil it.
    Jul 07 2004
    socal
    New maf went in.
    Part number on the sensor or on the housing? Might be time to just buy a brand new maf from a Audi parts shop or the dealer. Who knows what you actually got in the car right now seeing that it is different then what you had before. If you have a vag you better do some logging because if the maf is not the correct one your load readings could be completely way off causing the ecu to run way too much adv timing.
    Apr 22 2007
    Riverbank, Ca
    Same # on the housing. there isnt a # on the sensor, right?
    I dont have VAG, but I do have the cable for the ross tech. However I dont have a laptop :(.
    I'll see if I can get my friend to loan me his laptop.
    I was figuring I would have to get a new one.. ARG
