Results 1 to 9 of 9
    Veteran Member Three Rings miggity02's Avatar
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    Staggering the tires? Anyone done it?
    Wondering if anyone has staggered their tires. I'll be getting a set of non-staggered 18" and I was wondering if this is a good idea. Instead of 235/40/18 could I do 225/45/18 F and 245/40/18 R? Or am I just crazy?
    '17 SQ5-034 Stage 2 ecu/tcu-JHM 187mm CP-034 inlet, RSB, sub frame inserts-Eurocode trans/diff mounts-Alu Kreuz-B8/H&R-Neuspeed RSf72 20x9.5 et25-Magnaflow 11385-OEM airbox mod-aFe 11-10121
    Mk7 GTI-034 Stage 1 ecu/tcu-H&R springs/B8-Neuspeed rse11r
    Triumph Street Triple R-Full Arrow and tune
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    Re: Staggering the tires? Anyone done it?
    put the wider tires in the front, less understeer!
    Registered Member Two Rings
    Jan 19 2007
    01.5 S4 AVANT 6spd
    S. OC & PC UT
    ^^^ HAHA
    Bad for the AWD system. I wouldn't do it...
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    - Justin -
    Jul 06 2007
    Bremerton, WA
    Quote Originally Posted by rbooth View Post
    ^^^ HAHA
    wait seriously??? nah you're joking.
    dozens of people have been running staggered setups for years now without issues. staggered does not effect quattro in anyway as long as the diameters are within is it 5%?
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    these posts pop up all the time, and there is always some guy that who knows nothing on the subject and responds no.
    as long as they are close enough in diameter you should be fine. the 245/40 and 225/45 should be fine. use this website to see the diameter difference ~1% so you're ok.
    http://www.1010tires.com/TireSizeCal...?action=submit
    Jul 04 2008
    Seattle, Washington
    Quote Originally Posted by vdubstreets View Post
    exactly. And also the reason i posted 2 different links explaining why. One from Capt. and the other from Avanteix.
    - Justin -
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    Thanks guys. I'm still going to think about it.
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 10 2004
    east bay, CA
    225 up front, 265 out back.
    no probs at all.
    although. this is my daily. my next setup will be 235s all around. just to get it to be more neutral again, although, as is, it doesn't push that bad, but i don't push it hard enough to make the car want to push, thats what the weekend car is for : )
    - Benny
