Results 1 to 6 of 6
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    Boost gauge issue.
    So I've had my APR boost gauge for a while now and I have always felt like it reads a bit to high. A buddy and I did some loggs the other night and his ecuX was reading out 22.6psi, but my gauge was reading about 26.5.. Is this a common thing, or am I the only person having this issue?
    Apr 18 2007
    ny
    Re: Boost gauge issue.
    Which line did you tap into?
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Dec 11 2006
    Orange County,CA
    I cant remember the name of the hose, but is the one coming off the manifold. I know it was the right one.
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    22.6 is the max your that MAP sensor can read. So you are probably running what the boost gauge says, but the MAP and ecux can only read boost up to 22.6.
    B5 S4 Built motor GT28X's
    08 3.2 A3 DSG DD
    Dec 11 2006
    Orange County,CA
    Shit, that was the one answer that I was afraid of hearing. Ok so its back to the drawing board with my tune.
    Dec 11 2006
    Orange County,CA
    Quote Originally Posted by Blue AWD View Post
    Ok so I started looking at some old logs and one of them reads 22.94psi. If the map sensor only reads up to 22.6psi, and ecux is capped at that psi as well, how could it have read 22.94psi?
