Results 1 to 24 of 24
    Active Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    thinking of picking up an s4 avant
    What do you guys think?
    I'm looking for a platform to do an rs4 widebody with a built motor and a set of gt30's. Interior will be ripped out and the entire car will be repainted and caged. I'm just saving up before I pull the trigger so I need something I can put around in for about 10k miles. Think it will hold?
    Lots of miles
    2001
    161k miles
    6spd manual
    3 owners
    3rd owner only owned it for about 3 months and did the following maintanance.
    Axle Assembly: $150
    Axle Shaft-Replace-Each side: $124
    Temperature Probe: $85
    Tie Rod End: $228
    Valve Cover Gasket set: $127
    Cam Adjuster seal, 2.7T: $418
    Four Wheel alignment: $70
    Left CV boot shield:
    They want you afraid of your neighbors, your community, your family, your ability to support yourself, terrorists, climate change, China, Russia, Covid. As long as you are afraid, and won't unite red or blue, they win.
    Oct 31 2005
    Ashburn
    Re: thinking of picking up an s4 avant
    When was the last time the Timing belt was done?
    Sounds like an awesome build, search around there are a few already with what you crave.
    - Instagram: @Sinister_rs5-
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    What are you waiting for? Buy it now!
    Oct 27 2008
    B5 S4 Avant
    It's been replaced once but not a second time. It has been inspected though and was not recommended to be replaced immediatly.
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Quote Originally Posted by nthusiastt View Post
    If it has only been done once then it is DUE.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Oct 27 2008
    B5 S4 Avant
    Quote Originally Posted by 2k1audiS4 View Post
    according to the service manual inspection is due every 80k and replacement is due every 100. After confirmation of the maintanance records I'll determine wether or not to replace it immediattle or drive the piss out of it for 10k then park it and replace everything :)
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    dont fuck around with these cars or they will bite you in the ass
    that shit is way overdue
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Oct 27 2008
    B5 S4 Avant
    Quote Originally Posted by washyourrhands View Post
    Are you telling me the service manuals recommended maintenance schedule is inappropriate?
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    ^yes
    the homebrew'd s4
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    Quote Originally Posted by Overboostin View Post
    ^yes
    Agree, on both accounts
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Don't let the doom sayers scare you too much. If the belt was inspected by someone who know what they are doing you should be fine for 10k miles. The real important part is that you only drive it for 10k miles. If things get delayed and you end up at 20k+ miles you could run into problems. Plus with these cars you never know what you are going to get. It's a gamble either way with these cars when it comes to repairs.
    Either way I say go for it because it sounds like a SWEET project.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Jan 21 2007
    01.5 Silver Avant
    dc
    Quote Originally Posted by RolledMySTi View Post
    hows he know if the guy was any good, or if he really inspected it??? how do you inspect a timing belt??
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    yeah i still say change it so not worth the risk
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by casawhites4 View Post
    you look at it lol. if its coming apart its time to change it..duh.
    but i wouldnt be worried about the belt breaking .. id be worried about an aged water pump seizing or even worse a roller failing and causing the belt to slip 3 or 4 teeth. dont take your chances
    Oct 27 2008
    B5 S4 Avant
    Quote Originally Posted by ThirdStrike View Post
    a roller? Sorry not to familure with the audi build. Is a roller like a tensioner? I'm pulling the motor this summer for a full overhaul so I guess I'm not to concerned.
    Oct 27 2008
    B5 S4 Avant
    He has a receipt from the inspection. It's quite easy. You take the cover off and check for cracks. If your giving someone advise about a purchase you might want to take into account all possible variables....
    [rant]
    There's nothing more irritating than someone who is so soaked with fear that they just jump on and their only advice is "watch out or be careful, these cars will F you". No you as a driver will F yourself if you don't thoroughly inspect the car before purchase, you drive irresponsibly, and most of all aren't familiar with the service and maintenance that's involved. Saying be affraid is not good advice. Your not answering anyones questions or providing any sort of educational value. If your affraid of the car, it's because your uneducated. The proper suggestion would be to specify which parts need thorough inspection or don't post at all because in the end your not helping me get from point a to point b.
    I'm not afraid to tear the car apart and leave it on jack stands for a couple months while I figure out what a problem is or determine a solution. My motto is do it once do it right.
    [/rant]
    My last two builds and nobody touches my cars but me.
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    Lots of miles
    2001
    161k miles
    6spd manual
    3 owners
    Axle Assembly: $150
    Temperature Probe: $85 NOT GOING TO MATTER SINCE YOU'RE GOING TO DO A REBUILD
    Tie Rod End: $228
    Valve Cover Gasket set: $127 NOT GOING TO MATTER SINCE YOU'RE GOING TO DO A REBUILD
    Cam Adjuster seal, 2.7T: $418 NOT GOING TO MATTER SINCE YOU'RE GOING TO DO A REBUILD
    Four Wheel alignment: $70 NOT GOING TO MATTER SINCE YOU'RE GOING TO DO A REBUILD
    Left CV boot shield: NOT GOING TO MATTER SINCE YOU'RE GOING TO DO A REBUILD
    if you are really going to do a full motor rebuild and a all new body job and rip out the interior, i don't see how much of the stuff is going to matter. And why do you need to drive it around for another 10K before you do the build?
    if you're trying to save money you should just buy a complete junk-of-a-S4 (not necessarily salvage) and build it from there. Because like you said, you're going to rebuild the motor, so even if you buy a oil-burning S4 it won't matter since you're going to rebuild it, and since you're going to get body work done you should just buy a not-so-clean car for less money since you're basically doing full body work on the car.
    very nice cars BTW
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Jan 11 2007
    Salt Lake City, Utah
    Quote Originally Posted by Chknkatsu View Post
    very nice cars BTW
    Agreed.
    And I read somewhere just the other day that the rubber compounds they use in todays timing belts don't necessarily show their wear and defects like they used to, so you should not go off of a visual inspection anymore. Anyone know anything else about this?
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Oct 27 2008
    B5 S4 Avant
    Quote Originally Posted by jibberjive View Post
    Agreed.
    Alright lets get this straight..
    The maintanance schedule says 80k inspection 100k replacement. Have there been drivers who have broke timming belts before the recommended 100k replacement? If so, at what mile-marker? Do we have any forum data from members breaking belts early? I honestly don't know. I'm curious.
    Oct 27 2008
    B5 S4 Avant
    very nice cars BTW
    1st If I told you the price you would understand .... 2nd when did I say I was trying to save money? 3rd, if you buy a car that's in decent shape and build from there the oem parts that were on the car have a value to other s4 owners.
    To an even further extent if your a builder it's smart to pick up a car that's been modified as long as the modifications are quality. Reason being car owners sell their car with all these parts included for bones compared to what it would cost to replicate the build. You pick up the car. Drop off every modded part that you got almost costless and inclusively with the purchase and sell them for 60% of the value. You reap the benefits because the previous owner didn't want to part it out. Also with these past two methods you avoid annoying things like body rust and previous collusions that could have jarred the subframe. With a junker your rolling the dice on everything.
    Not only that you can drive the car around as is for a while and enjoy it. I like to see how the car feels and get comfortable with it before I mod the piss out of it. The build is that much more valuable to you if you are comfortable with the car in stock form and understand it then feel the difference of each and every modification.
    Jan 11 2007
    It's already been straight told to you above, that car is well due for a timing belt change. General consensus is 60k mi timing belt change NOT the 100k of the book. People have broken belts.
    LOOKING FOR:
    Feb 08 2008
    Whitestone, NY
    well considering you're getting the car for cheap, I say go for it. And I do agree that parting out a modified car will break even on the cost of the car, on that note, is this car already modified? if so, you're going to sell the modified parts and put on stock parts?
    $4c@b
    WGLYC
    S4SugarHips
    Oct 27 2008
    B5 S4 Avant
    No... It hasn't been straight told to me dickhead. I got a "it's way over due for timming".. That sure is informative I better rush down to the audi dealer and change the timming belt because a forum member said so.. I ,and many should, need a logical explanation before disobeying Audi's recommended maintanance. People have broken belts prior to the 100k according to you. How often does this happen? Again do we have any forum data or anything for me to research your theory closer?
    Feb 08 2008
    Whitestone, NY
    it has happened plenty of times, but if you feel it is safe to putt around for 10K then go for it. maybe you can rebuild your valve train too
    $4c@b
    WGLYC
    S4SugarHips
