Results 1 to 22 of 22
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    Owners who installed Bi-Xenons and got hi-beams to work
    I installed my Bi-Xenons from Jens a few weeks back, but after vagging, was never able to get the hi-beams to work. We checked the lights, all good, and verified the 21 and 22 ports on the ecu plug. My lights are awesome, just the hi-beams don't work. I was wondering if anyone has installed their xenons AND successfully got the hi-beams to work, if they can share the knowledge that I currently lack?
    Where did you run the 2 thin grey wires (assuming the two wires for the hi-beams are all grey)?
    I have a base B7, thanks for any help.
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
    Sep 15 2005
    Norwalk, CA
    Re: Owners who installed Bi-Xenons and got hi-beams to work
    I followed this guide, and it works fine.
    What happens when you switch on the high beams? does the city light come on instead?
    Peter
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    Kufatec?
    I would imagine the harness should be nearly plug and play
    The harness is designed to bridge the gap between a halogen car
    and HID Bi xenon setup...mine are working great although
    I do get flashed becasuse I think they're a bit brighter being that
    they came off of a RS4 in the UK?????
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
    Feb 05 2008
    Orlando, FL
    Yes, Kufatec harness from Jens. I followed the same walkthrough linked above. Before I VAG-ed, the hi-beam switch did the inside halogen. After VAG-ing nothing happens when I flick the switch. We checked the lights, so I;m not sure what it could be.
    Dec 20 2007
    Colorado
    ^^^that is odd!
    I guess at this point I'd be taking it into a trusted Audi tech
    Luckily I had one help with the install so it wasn't a prob,
    but if you know someone in a knowledgable place, now might be the time???
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Yeah i got lights from Jens a while back as well and i have no idea where to plug the high beam lights to. Its just two wires wrapped in this cloth type thing. Ill take a pic..in a sec to show you guys.
    Maybe someone can shed some light on it...
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Dec 11 2007
    San Diego, CA
    ok, nevermind i saw it on the link. Looks pretty easy. Thanks peta!
    FRRG Southern Ring
    Feb 05 2008
    Orlando, FL
    Follow the link above that peta8368 posted. It will show you where they go. However, that did not work for me.
    Dec 11 2007
    San Diego, CA
    yeah im going to try it out now.
    FRRG Southern Ring
    Feb 05 2008
    Orlando, FL
    Make sure to unplug your battery first!!
    Dec 11 2007
    San Diego, CA
    ok i got the wires in but only the passenger side high beam works. The wires werent labled like it said on the write up so i just put one in the 21 slot and the other in the 22 slot. I tried taking the wires out but they got stuck like in the gap part of the plug. I wonder if i switch them around if they might work.
    Anyone got any info on this?? Or how to take the wire out? The metal clip part gets stuck on the gap and wont want to budge out. I dont want to break anything.
    FRRG Southern Ring
    Dec 11 2007
    San Diego, CA
    Kid- sorry for thread jacking!! lol Ill wait till my roomate gets home he is a VW Tech im sure he will know whats up. Good luck getting your high beams to work.
    FRRG Southern Ring
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by Kid Red View Post
    did you make sure to connect the wires under the dash? that's what you need to do after Vagging it
    DUH! an Audi
    los angeles, CA
    This is very strange, here are some of the potential problems: A) you did not correctly plug the wires into the pins. B) you plugged into the wrong plugs. D) Did not vag correctly for bi-xenon and lastly the flapper inside does not work.
    Possible solutions:
    - get those two wires and find a positive and negative wires, similar to the low beams near by and test if the flapper motor works. This can also be achieved by directly connecting to the battery.
    -check vag com codes, ensure they are correct
    If you connect the wires directly to the battery/power source and it works, than you can trouble shoot your plug not being connected properly or connected at the wrong pin location.
    PS: There is no way, that I was able to find to NOT connect the high beams to that ECM? location. When I installed, I tried to find an alternative from running the wires inside the kick panel location. You cant use your oem wiring to make this work, I couldn't get it to work, but if some did please chime in!
    Try this out and let me know.
    -randy
    Feb 05 2008
    Orlando, FL
    Good stuff guys.
    Yes, I ran the two grey wires to pins 21 and 22 on the correct side of the plug (17-32 marked). Jens troubleshooted (is that a word) the lights with me and there was a definite loud clunk sound on the hi-beam wire on the light end of the harness doing a battery test. I Vag-ed for the bi-xenons following the $20 VAG thread, can't recall off hand the exact code, but I have the no turn signal on currently.
    So, what I know for sure:
    -One light did clink with a battery test (we assumed the other light was fine as well)
    -Pins are in 21 and 22 and I have switched them around just to be sure.
    -I have vagged a few times/codes (halogen, bi-xenon, no turn signals, DRL, etc)to what I believe is the correct code
    I mostly wanted to verify those who got it working used the same 21 and 22 slots, and that those are the same across base, S-Line, 06, 07, 2.0t-quattro, etc. I don't have DRL either in case that makes a difference. Otherwise, I'm not sure what else to try.
    Feb 05 2008
    Orlando, FL
    Quote Originally Posted by Sal_B7 View Post
    Hey, you got one working, that's half way there! The wires can be removed with a small screw driver, just push down on the flap and pull it out. I wish I knew why you got one light to work at all, and why you didn't get the other light to work at all.
    Dec 11 2007
    San Diego, CA
    Yeah last night my roomate tried to pull them out and broke both metal plugs. He got me new ones today so i got it hooked up and same thing happend again. So i switch the plugs and bang!! They both work now. so yeah im all good on my hi beams now.
    Im not sure on the whole vagging part. My roomate did it for me at his work. But hopefully you get it taken care of.
    FRRG Southern Ring
    Feb 05 2008
    Orlando, FL
    Congrats. So you ran the two thin grey wires to 21 and 22 and any chance you can ask your roommate what code he VAG-ed?
    I'm a at a loss. Maybe my wires aren't getting a good connection? I'm not sure what else to check.
    Dec 11 2007
    San Diego, CA
    yeah i ran the wires to 21 and 22. I doubt he remembers. He did it a long time ago. He did it on his OBD thing at his work (VW) but ill ask him.
    Im not sure what else to tell you. Not sure where to go from your point.
    FRRG Southern Ring
    Senior Member Three Rings MichiganAudiDvr's Avatar
    Nov 19 2008
    2007 Audi S4; 2007 Chevrolet Tahoe LTZ
    MI
    I think you should just uninstall and send them to me so I can try them out on my car for you! (half kidding)
    Anyway, I have scoured the forum for something that could help you out and can't find anything. Perhaps you have a bad harness...but I don't know, I am just guessing.
    Sep 15 2005
    Norwalk, CA
    I think you should try connecting them directly to the battery again, and see if you can verify that both at making the clunking sound.
    I am thinking that either your kufatec harness have a bad wire/connection or the wires inside the housing is bad. If anyone know how to test those things, perhaps we can further narrow it down.
    Peter
    Feb 05 2008
    Orlando, FL
    I tested the hi-beam continuity with a battery on the left headlight and clearly, heard the clunk. I can try the same on the right side just to confirm that they both due work correctly. But I have verified on the left light, the hardness/light and hi-beam wire is operational.
