Results 1 to 9 of 9
Thread: headlight out!
    Senior Member Two Rings mattiouti's Avatar
    Jul 29 2007
    2003 A4 Quattro
    Tampa/ St. Pete, Fl
    headlight out!
    ok...i had my left xenon go out on me last week. It said "dipped left headlight" in the info area. So the bulbs are 7 years old and i automatically think to replace them. So i did......and i still have the same problem. Any ideas or suggestions? Im thinking the ballast maybe? but i am at a loss for thoughts...Do the headlights have a seperate fuse for each one? any help is appreciated
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    Re: headlight out!
    I'm in the same situation, except my light is out on the passngr side. If you checked the bulbs and they're OK, you're best bet is the ballast. Swap them out and test it...
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Re: headlight out!
    You can always test your bulbs with the good ballast and determine your problem.
    -Matt
    FCDT Member #1
    Jul 29 2007
    2003 A4 Quattro
    Tampa/ St. Pete, Fl
    Re: headlight out!
    I used both brand new bulbs on the headlight that was not working and none worked. I put one of the new headlight bulb in the working headlight and the bulb lit up. So I kno the bulbs are good. So either a ballast on the drivers side or blown fuse/open wire? Where are the ballasts located?
    Jul 30 2008
    Downtown Denver, CO
    Re: headlight out!
    Quote Originally Posted by mattiouti View Post
    Depends on what kind of headlights you have. If your HID's are an aftermarket conversion kit, the ballasts will most likely be mounted outboard of the headlight housing but you'll see wires travelling to them. If they are OEM xenons, then i beleive the ballasts are located in the housing right behind the lowbeam bulbs. Someone correct me if i'm wrong as i don't have OEM HID's.
    -Matt
    FCDT Member #1
    Jan 09 2008
    California
    Re: headlight out!
    check this link http://www.audizine.com/forum/showthread.php?t=189127 it might help you out with locating the ballasts.
    Veteran Member Four Rings Raus's Avatar
    Aug 18 2005
    B6 1.8TQM, Mk2 GTI
    Re: headlight out!
    Yeah, been there done that, it's almost certainly the ballast.
    On regular xenons the ballast is on the bottom of the headlight housing, on bi-xenons the ballast is on the back of the headlight cover. You'll need a security torx bit to remove it.
    Ich bin der Musikant mit Taschenrechner in der Hand
    Jul 29 2007
    2003 A4 Quattro
    Tampa/ St. Pete, Fl
    Re: headlight out!
    alright then thanx for all the help. next step is finding a ballast. Do i dare go to audi?
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    Re: headlight out!
    i wish i could afford HIDs :( left dipped went out on me this morning too
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
