Drag about your brake problems. From your description, it really does sound like you have air in the lines. It is possible that the shop you took it to did not seal one of the bleed valves properly when they flushed the system. Also possible that you have a leak somewhere allowing air into the system. I would think you would have noticed before now, or the shop would have noticed when flushing the system... time to climb under the car.
Bleeding the brakes is VERY easy. I'd invest in a power bleeder before paying someone to flush the brakes, but that's just me. Or, just ask a buddy to spend a few minutes pressing the pedal as you open and close the bleed valve.
SS lines will improve pedal feel, as will better (not just new) brake pads.
Originally Posted by
trueno429
if it bothers you that much get some new pads, you got the car used right?
even if you dont need new pads lets say for example just get new ones. it will obviously decrease travel for obvious reasons. less piston poking out
This is just plain wrong.
The pistons do not fully retract when you let up on the brakes, it simply relieves pressure in the line. Pistons will gradually extend farther out of the caliper as the pad wears, but the piston is effectively moving the same distance when the pads are new vs. when worn.
