Results 1 to 8 of 8
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Problems keep showing up, some info please
    I've the Airbag light and the ABS w/ flashing Brake light since I bought the car over 2 weeks ago. I went to the Berkeley Marina Meet and SeKKeY checked the codes for me (Thanks! ). These are the following Codes:
    18014: Rough load/signal
    Using search, I found this means the ABS module has gone to the shitter.
    65535: Internal Control Module Error
    Using search (OMG, again?!) I found my Airbag Control Module is also in the shitter.
    01367: Central Locking Pump run time
    I have no idea what this is, sounds like it has to do with the locks on my car, which work fine.
    My question is which of the modules can be rebuilt, I keep mixing them up. I read that someone on here can rebuild the module for like $50, can I get a pm on who that is?
    Also, SeKKeY had done something that had to do with seeing if the car would pass smog, and it came out saying that my cat and sensors are crapped/failed. I decide to leave the meet after getting to know some fellow Audiziners (see some of you on friday!) and checking out cars, and what do you know, another problem shows up! When I floor it, it seems that one of the coil packs are dead, and they were all replaced relative recently (say that 5 times fast). It happened after the VAG, cause when I floored it on my way to the meet, I had no problem (except the dentist drill noise).
    Lots of problems, some assistance needed. Please help me to bring some balance to my car.
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: Problems keep showing up, some info please
    did you clear the codes? did they come back?
    looks like you need a new ABS module, modulemasters
    Jan 29 2007
    08 S4 00 S4
    MD
    The central lock pump run time exceeded is probably vacuum leak, not that big of a deal..yet..
    Did you do spark plugs with the coil packs?
    08 S4- Stock SOLD
    Feb 15 2008
    Sacramento, CA
    infinkc: We tried clearing the codes, but they wouldn't go away.
    mholme: Vacuum leak actually sounds right, I typically hear what sounds like a leak/whistle type sound when I'm barely on the gas (no boost/psi being applied). I will definitely replace the spark plugs and coil packs today after class myself. See if that fixes the issue (probably will once done, but will have to see in the long run).
    Feb 09 2007
    00 S4
    MA
    not an engine vacuum leak, the central locking system is a vacuum system in itself. there is a leak in one of the lines that go from your trunk (where the pump is) to all the doors.
    you can also get this code if you unlock the car with a partially dead battery.
    the ABS module can be rebuilt by kompresed on this forum for 50 bucks
    the air bag code is more than likely a module failure
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Feb 15 2008
    Sacramento, CA
    Cool, thanks for the clarification Blake. I'm not going to worry too much about the locking system yet, focus on the engine/electronic stuff first. I'm just gonna go all out and buy a new battery, coil packs, spark plugs (Chipped, so 0.28 spacing right?), contact kompressed about the ABS, and once I get the another paycheck, I'll work on replacing the Airbag Control Module.
    I should probably invest in a boost gauge too. Time to go shopping!
    Jan 29 2007
    08 S4 00 S4
    MD
    I wouldn't change coil packs since you said you replaced them recently. How long ago? Start cheap with the spark plugs.
    08 S4- Stock SOLD
    Feb 15 2008
    Sacramento, CA
    I need to check with the coil packs on the receipts, as it was the previous owner who had them changed and IIRC, they were done at separate times individually over the past 6 months, all 6 of them.
