Results 1 to 16 of 16
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Sputtering on Cold Start
    Ok so here is the issue I will try to be very clear with everything....
    In the mornings the car sputters for about 30 secs..... While the RPM's are high and the car is warming up..... At first I thought it was the head it was cracked and maybe droplets of water trickeld down on the piston... etc
    Anyways got the head redone everything is good and boom started it up yesterday in the morning it was around 60 degs... and it sputters the check engine light blinks for about 30 secs then it is perfect..... When you go to take off its almost as if you have a huge boost leak and will almost back fire.... Once It warms up thats it... Its smooth as ever.....
    - Its not boost leak because I hold 20psi with no problem and did a test...
    - Coils packs are new
    This is what I have if this helps
    - Giac FX
    - 380cc injectors
    - SAI Pump Gone
    I searched and I read one thread where it said it was possibly a fuel pump or filter but I changed mine about 15K ago ( the filter )
    Thanks
    Registered Member Two Rings
    Feb 07 2008
    04 A4 1.8t 6spd
    stratford ct
    Re: Sputtering on Cold Start
    some people had problems with injectors in cold weather. you can check your spark plugs and change valve cover gasket ..
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    60deg isn't exactly cold weather. My car runs rough for about a minute when i start it, but i'm talking in 0deg f.
    Veteran Member Four Rings BlackB6's Avatar
    Apr 03 2008
    Pennsylvania
    I don't think hes refering to the weather when he meant a "cold start".
    Sep 23 2006
    Las Vegas, NV
    ^^^^^^ I was actually stating the temp just to note it wasnt really cold outside.... Like up north.... Even though 60 degs is considered a COLD morning in South FL...
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    Myne kinda does this too, What injectors do you have, exactly?
    02 A4 3.0Q6MT
    -chad
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    I thinkl it is a giac 380cc thing, mine is a little rough as well in cold and on cold strt up for a 30 sec to a min or so, same at 10 deg as at -20 deg F. I think it is a giac thing. Iam thinking of getting the unitronic or apr tune with 225TT injectors, I have heard it to be a smoother combo overall, although I know many will chime in saying otherwise, all I know is what mine does.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Sep 23 2006
    Las Vegas, NV
    Quote Originally Posted by ziggituning View Post
    They are white injectors I do not know what brand it is but I searched and it looks like only people with Gian has this problem..... It sucks becuase It makes your car sound like crap......
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Mine runs rough at first for 30-60 secs and then runs fine..i'm guessing mine is due to the battery though
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Oct 07 2008
    East Texas
    Quote Originally Posted by HeymyA4 View Post
    Thats exactly what injectors I have, They are known for doing this. But my symptoms are a little different from yours. Myne only studders for a new seconds, then everything it perfect, and my CEL is always on anyways so I don't notice. But yeah it's the injectors.
    02 A4 3.0Q6MT
    -chad
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I have to agree with chadb2434. The problem is with the Bosch 380cc injectors. This has been a common complaint for years. The single cone spray just doesn't atomize well enough for a cold start. And yes, even 60 degrees can be considered a "cold" start. I have been running the Genesis 380's for several years with no issues with temperatures below 0 degrees F.The Genesis have a dual cone spray similar to the TT225's. However with that being said, the Siemens 380cc single cone spray seems to work better than the Bosch 380cc ones. Once warmed up the Bosch 380's should perform fine.
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    OK are the bosch 380 injectors white or black? I thiught they were black, I wonder if the giac 380 cc file works with the TT 225 injectors as well.
    Dec 28 2006
    Western Maryland
    The Bosch 380's are white. The GIAC file should work fine with the TT225's.
    Sep 23 2006
    Las Vegas, NV
    DAMN DAMN DAMN!!! Just what I was thinking........ Those darn injectors !!!! Well Im going to have to check out usrt and see what those are going to cost me...
    Oct 07 2008
    East Texas
    yeah that would be the best, IMO
    02 A4 3.0Q6MT
    -chad
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Mine are black and are 380cc (installed by previous owner, do you think they are the genesis?
