Results 1 to 2 of 2
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Acceptable Knock Voltage Range
    Trying to figure out if my car is running properly. Been doing some logs and have been getting some high timing CF's (8-11* in every cylinder).
    So today I did a log of knock voltage and am seeing as much as 17V in each cylinder. Is this something to worry about?
    http://spreadsheets.google.com/ccc?k...gp1aPI52nzICNQ
    Downoadable version:
    http://www.mediafire.com/?sharekey=8...4e75f6e8ebb871
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Nov 25 2007
    Re: Acceptable Knock Voltage Range
    Any one...
    Some Go, No show
    Wish List
