Results 1 to 11 of 11
    Sep 04 2008
    2013 A6 3.0T
    Stock sport suspension with 245/35 tires on 19x9" ET35 wheels?
    Will I have a problem with those wheels/tires on stock sport suspension?
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Re: Stock sport suspension with 245/35 tires on 19x9" ET35 wheels?
    im about to mount 255/35/19's on a 19x8.5 et35 on wednesday. guess we'll find out lol
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Senior Member Three Rings edwardabodnar's Avatar
    Mar 08 2008
    Miami
    i have been running 245 30 20 for some time know I was told by a rep at tire rack on their forum that this setup is perfect as it is very close to the stock setup in total measurement.
    Sep 02 2005
    Montreal
    Quote Originally Posted by eurogruppe View Post
    I take it you must hate tire stretch big time. 8.5" wide wheels are bellow the minimum recommended wheel width for that tire size, just so you know...
    Sep 02 2005
    Montreal
    Quote Originally Posted by edwardabodnar View Post
    He's wrong, 235/30-20 is the equivalent of stock. (less than 1% difference in rolling diameter). 245/30-20 is almost 2% larger.
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    yea i know but i got a good deal on the tires. if i dont end up liking the way they look ill just sell them and get different ones
    Dec 03 2005
    2 pedals 1FG
    connecticut
    How did it turn out?
    -Doug
    Sep 04 2008
    2013 A6 3.0T
    Thanks everyone.
    eurogruppe, keep us posted on how it turns out.
    Anyone running 9" wide rims with ET35?
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    You're right but no one stocks that tire and only a few companies even make it. I wanted that size but it was hard to come by.
    Quote Originally Posted by audinuts13 View Post
    Thanks everyone.
    German Driver was running 19x9 et33 sportec wheels on his B7
    Sep 04 2008
    2013 A6 3.0T
    German Driver was running 19x9 et33 sportec wheels on his B7[/QUOTE]
    Thanks for the info. I suppose he's running an aftermarket suspension. Will that make a difference, other than rubbing against the fenders (potentially) ?
    When I got under the car, I saw this metal bar running from the hub area to the top of the wheel arch. I take it that it's an upper control arm, correct? There's only like slightly less than 2cm of room to spare between the tire/lip of the rim and the metal bar. I'm currently running 18x8 ET43 wheels. Will 245 tires be too wide and rub against the metal bar if I run those 19x9 ET35 rims on stock sport suspension?
    Sep 04 2008
    2013 A6 3.0T
    anyone?
