Results 1 to 10 of 10
    Veteran Member Three Rings 3 bar's Avatar
    16 SQ5, 14 A7 Tdi, 91 Corrado, 02 Passat wagon, 99.5 A4 TQM
    Greensboro NC
    Anybody had motor or trans mount issues?
    Ive been showing left and right upper motor mount solenoid short to plus reading for a while. Now the car is shaking like crazy and is getting hard to shift so im thinking the trans mount has collapsed as well. Any comments/ suggestions? Thanks.
    2004 Atlas Grey A4 Avant
    1999.5 Volcano Black Audi A4 1.8TQM
    2002 VW Passat wagon 1.8t 5 speed
    1991 VW Corrado 1.8t w/matching trailer Waterfest 03/04 winner (show)
    1980 Chrysler Cordoba LS 371ci 450hp 12.68(go)
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Re: Anybody had motor or trans mount issues?
    humm possibly. What do the solnoids do for the engine motor mounts anyways
    Greensboro NC
    they electronically counter the imbalances of the motor. Why rubber mounts wouldnt work is beyond me!
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    I've had a motor mount replaced. The car was torn apart for a clutch job and the motor mount was oozing some odd fluid.. No codes though...
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    As far as I know, there aren't any aftermarket rubber mounts available. The car shows a solenoid short circuit code when the fluid leaks out and the mount collapses. This happened on my b6, but I traded it in before I got a chance to install the new mount. I have a brand new oem mount for sale in the classifieds section if you're interested. I'm negotiable on the price, since it is of no use to me anymore.
    - Pat -
    2016 RS7
    -Previous-
    2013 S6 Prestige, 2010 A6 Prestige/Sport package, 2012 A4 Avant S/line, 1991 Coupe Quattro, E55 AMG, 2009 A4 Prestige, B5 S4 avant, B6 S4, C5 RS6, B6 S4 avant, 71 El Camino SS
    Jan 14 2009
    pasadena md
    so thats why you cant feel hardly anything when the engine idles
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    How much labor to replace mount?
    Nov 16 2008
    Hudson, WI
    Alldata shows 0.8 per side, but that may be a little low. I think you might have to drop the AC compressor on the passenger side.
    - Pat -
    2016 RS7
    -Previous-
    Jan 10 2007
    Earth
    My service guy did it for 30 minutes time when he was changing the snub and clutch.. said he had it most of it apart already.
    2013 White 911 4S
    2005 Moro Blue S4
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    The trans mount is rubber.
    The motor mounts may be able to be replaced with a B5 aftermarket mount and you would have to install a resistor (once you ohm check the mount to see what the computer will look for) in the the wiring to get the code to go away. I have thought about looking into this. They look similar
    I have a car in our shop right now, I will see what I can find on it. Probably won't be able to test fit any B5 mounts on this one. But I will try to take a closer look.
    As for fixing your problems, have you tried unplugging the wires to see if the code is no longer short to plus??? It should switch to an open circuit code. Obviously clear the codes after unplugging them. If the code is still short to plus with the mounts unplugged and you clear the codes then the wiring is screwed up somewhere. If the code is different then the mount(s) are bad.
    Hope this info helps.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
