Results 1 to 9 of 9
    Established Member Two Rings mefischer77's Avatar
    May 10 2008
    2005 Allroad 2.7t Stealth
    Breckenridge, CO
    Front grinding.... Bearings?
    So lately I'm feeling some "grinding" or rough riding when coasting or coming to a brake or turn at lower speeds. I know it's not a brake issue, and feels like wheel bearing wearing out. It's just not a super smooth ride. Anyone had this issue, and what was the findings?
    I feel the same thing on my pop's A6 when he goes into deep turns on the highway or something... his is a '01, so figured it was his bearings.
    If bearings, what are good aftermarket options? - if better/less pricey then dealer fix.
    Senior Member Three Rings Chopstixs's Avatar
    Jan 22 2008
    2.8 Single Turboed A6/2011 Tahoe
    Va
    Re: Front grinding.... Bearings?
    Get that fixed soon, mine locked up on me the other day!
    Through out the years, People have used "Chopstix" to eat rice.........I do the same.
    C5 UNION MEMBER
    May 10 2008
    Breckenridge, CO
    were your symptoms the same? how did you fix?
    Aug 27 2008
    lincoln nebraska
    if its a wheel bearing you should not be driving it, that will be a catastrophic accident waiting to happen. get it looked at asap.
    Registered Member Two Rings
    Mar 04 2007
    check the brake dust shields....
    PM OR EMAIL ME ABOUT:
    POWDER COATING AND TRIPLE PLATE CHROMING
    Email: kyle@signsilo.com
    Jan 22 2008
    Va
    Quote Originally Posted by mefischer77 View Post
    First I thought that I had a flat because the car felt funny, pulled over and looked around, no flat. Got back in got about 3 feet locked up, The front wheels had a lot of camber. Glad it happened when it did, I was doing 100+ couple min earlier
    C5 UNION MEMBER
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    im doing wheel bearings when i get my stern control arms put on....where can i get some at?
    they have them on ecs http://www.ecstuning.com/stage/edpd/...ory=Drivetrain
    but do you guys know if thats a good price?
    also do you guys recommend replacing the housing with bearing or just bearing ?
    2004 Audi A6 2.7T
    Jan 22 2008
    Va
    Quote Originally Posted by FrankA6 View Post
    I did the housing as well
    C5 UNION MEMBER
    May 10 2008
    Breckenridge, CO
    Sprayed it out, and still rough at slow speeds.
