Results 1 to 7 of 7
Thread: Fog lights?
    Established Member Two Rings Chb04's Avatar
    Jan 12 2009
    11" B8 Sedan , 07" B7 Avant, 11" Jeep Wrnglr Unlmtd
    USofA
    Fog lights?
    Should the fog lights be able to be turned on if your not using the headlights? Every other vehicle I've had you were able to use just the fogs when you needed them. I have halogen headlamps and no auto on. I'm thinking I have a bad switch?
    Sep 13 2008
    Western Chicago Burbs
    Re: Fog lights?
    nope. thats the way they all are. you can vag it and sit it to rest of world or canado if you want indipendent fogs. you can also modify the swich. us the search. look up indipendent fogs
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Re: Fog lights?
    You need to modify the switch to do so. Not that hard; takes about 5 minutes
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Re: Fog lights?
    how would one go about doing that? Is there a helpful link out there?
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Veteran Member Four Rings B6bomber's Avatar
    Jan 05 2009
    05 B6 S4; 98 Nissan Altima
    LA area, Back in Simi
    Re: Fog lights?
    I was wondering the same thing this weekend. I have a B6 S4 and I was driving through some fog and I noticed that I could not turn on my fogs unless I switched the lights from Auto to manual mode. Seems weird that you cannot turn on the fogs in Auto mode. Guess i will just have to rig the switch.
    Established Member Two Rings cjnesher's Avatar
    Oct 31 2008
    DG 05 A4 2.0T 07 Passat 2.0T
    Tampa, FL
    Re: Fog lights?
    Here's the DIY
    You can do a search and find this stuff too.
    http://www.audizine.com/forum/showthread.php?t=124534
    Dec 11 2008
    '08 A4 Avant SE, '99 4Runner
    Westminster, CO USA
    Re: Fog lights?
    I recently did the switch mod on my B7 Avant and no Vag was required.
    I decided to jumper the pins and cover the end of the one pin rather than cut the wire behind the switch.
    Took 5 minutes, now I can run fogs with parking lights independent of the headlights, except in Auto Mode.
