Results 1 to 13 of 13
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Extra bolt from clutch/stage 3 install
    I just put the motor back in place and I have a bolt that I have no clue where it goes. I wrote on the bag it was in Driver Inlet Bolt yet I have no idea what I meant by that and where it goes. I have Generationjdm's inlet pipes so there are no bolts and it's too big to be the old k03 inlet bolt. I don't have a passenger one, just driver. It's a 13mm M8 bolt. Any ideas where this goes?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Oct 31 2005
    Ashburn
    Re: Extra bolt from clutch/stage 3 install
    The bolt that holds the bi-pipe in place right where the upper intercooler hose meets the bi-pipe. It bolts on to the plastic cam covers i think.
    - Instagram: @Sinister_rs5-
    Jul 06 2007
    San Jose, CA
    No. I have those and they are way smaller. Thanks for the help though. Any other ideas?
    May 22 2007
    East Bay, Ca
    Is it flat or pointed on the threaded end? If pointed then it would have been for the air inlet pipe to the turbo.
    Jun 01 2008
    Apopka, FL
    if it's a 13mm, my guess is the bolt that holds the main coolant res hose to the block(it has a flange that bolts to the head/block to keep it from moving.).
    Oct 31 2005
    Ashburn
    ^^ ok if it's the inlet bolt then the inlet bolts to the valve cover right? check that
    Nov 15 2006
    00 S4, 99Cobra, 54BelAir
    The Milky Way
    leave it off, weight reduction!
    Jul 06 2007
    San Jose, CA
    Quote Originally Posted by code7rpd View Post
    It's pointed on the end has has about 1/4" of no thread on the end. The inlets I have don't require bolts so it shouldn't be that.
    Jul 06 2007
    San Jose, CA
    Quote Originally Posted by blmlozz View Post
    Nope I have that one on.
    Jul 06 2007
    San Jose, CA
    Nope those are smaller.
    Oct 31 2005
    Ashburn
    That's right you said 13mm so that isn't reallt that small of a bolt. only thing i can think of are the bolts that hold the bottom portion of the fender to the body of the car. there are 3 of them on each side. that's all i can come up with, hope you understood what i meant.
    Jul 06 2007
    San Jose, CA
    That was it. I am installing my clutch for the second time in a row (A long sad story that I will post about once it is all done) and that bolt was left over from last time. I didn't take them off the second time because I have generationjdm's inlets so I couldn't remember where it went. Thanks for all the help guys. I was starting to go insane with this car. I have been working on it since the day after Thanksgiving.
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    i believe that bolt might be from the side, when u take the bumper off and see the 2 flaps sticking out by the intercoolers. wheir the horn is right above it
