Results 1 to 10 of 10
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    How many of you have Corner Balanced coilovers?
    I have had coilovers on my car for a few years now and have never had them corner balanced. For those of you who have had it done, did you notice a big difference in handling?
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 25 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    Re: How many of you have Corner Balanced coilovers?
    Ive wanted to do this, but as i searched everyone says its overkill on a daily driver and a waste of time and money. But i still would be interested in doing it.
    Dec 11 2006
    Orange County,CA
    I found a place that will do it for $150.00 which isn't all that bad. Even if its a daily driver it never hurts to have a car set up properly. I was just hoping that someone would chime in who has it done to their own car so I could hear about the before and after results.
    Established Member Two Rings Alex@VAG's Avatar
    Feb 23 2008
    Montreal
    Corner balance along with a proper alignement (not factory specs) has always been the one thing that made the biggest difference on handling and lap times on any car of any brand I've owned.
    Active Member Two Rings Jig74mg's Avatar
    Apr 20 2007
    2001 Sliver S4
    It was something I thought about doing for some time too, but kept hearing that its a overkill for a DD. I also heard that corner balance is beneficial for mostly track use only. However, I went ahead and recently just got my car corner balance...Its not a major difference, but if you are really tuned into your car, you will notice it...My car does feel better in steering response; its sharper but so far this is from only aggressive street driving. I think i should see a better difference during my next track event with high speed cornering ability, and the weight transfer during braking. The question you should ask yourself is how aggressive do you driver your car daily or how often do you track you car? Personally, for the price of $150, it’s worth it.
    SOLD: Stage III
    Veteran Member Three Rings road race s4's Avatar
    Jan 03 2009
    camry
    I did it on my Galant Vr-4 when I first installed my HotBits coilovers. The shop corner weighted and aligned the car. Huge difference in the way the car handles on the street. Paid close to $300 including taxes and what not but well worth it. If you're going to install coilovers and not do an alignment and corner weight then you might as well keep the stock suspension.
    Dec 11 2006
    Orange County,CA
    Thanks for the input guys, I do about 4-6 track days a year so it looks like I will go ahead and get it done then.
    Jan 29 2007
    08 S4 00 S4
    MD
    How do you even truely corner balance a car that's using rubber bushings all around, non adjustable control arms and drop links? It's a waste of money for a street car in my opinion.
    08 S4- Stock SOLD
    Veteran Member Three Rings CHEROHALA's Avatar
    Aug 24 2005
    2002 s6, 2013 Touareg TDI
    $150 seems really cheap. When I had my s4 done (corner balanced with a wheel alignment) it was a 3-4hour operation (I sat in the drivers seat for most of it). You wont feel much difference on public roads unless you drive like a dick. On the track, handling is more crisp and your S4 pig will feel much lighter.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by CHEROHALA View Post
    That is dirt cheap. A proper corner balance is going to be like you said 3-4 hours at a minimum.
    08 S4- Stock SOLD
