So this has been going on or awhile now the car sits @ 15hg while idling after warm up. Since i moved and now have a garage i just bought a compressor this weekend. I decided to try and put an end to this leak or whatever it is. while pressure testing I sprayed soapy water over every hose.
1. Leaky diverters- I tightened them and there fine now
2. leak near TBB- just had to tightrn the clamp
3. Big leak in the passenger side stock intercooler.
I thought 3 was the big ticket i took the whole bumper off and see the water drip and hit the spot where it was leaking. it looked like Moby Dick's port hole blowing water. I texted a local member to about the issue and later in the week he's going to let me get he's stock one's but for the meen time i used gasket seal and bondo to cover the hole. after I let it dry I re-installed it and pressure tested again. Didn't blow any air and i couldn't hear any escape or see any soapy suds. Put the car back together and started it back up hoping for change and THE ****** IS STILL @ 15hg.........................WTF
I was thinking valve cover gaskets of maybe intake manifold were leaking but couldn't tell and 15hg @ idle would have to be a big leak, so why can't i find it?
After the car was together i warmed it up and took a test drive, and it pulls hard and the siren isn't as loud as it use to be so that made me happy a little but why 15hg.
Also I'm currently running stock intake w/ darintake mod.
Any help please, I want to go STG 3 this summer but i won't until i find out what is wrong.
Vernon
