Results 1 to 17 of 17
    Veteran Member Four Rings kurupt_hawaiian's Avatar
    Oct 13 2007
    2017 Toyota Tacoma TRD Off-road
    Waianae, Originally Molokai
    Stud broken off of turbo
    So i put my VMR test pipe on my car and noticed that i had to torque the nuts down a little more on the turbo side of the test pipe because it was leaking. So i try to tighten it a little more without even putting that much pressure the stud breaks off. At first i thought the socket just fell off of the ratchet, but when i pulled the ratchet out the socket was still there. This is what i found under the car. Sorry for the blurry pics, took with my phone.
    This just ruined my day! Anyone know about how much it would cost to get this fixed? Its just one stud. Its the top stud on the engine side of the turbo.
    Active Member Two Rings Mecartay's Avatar
    Sep 12 2005
    MK1, MK3, 2 B5s, and a B5.5
    Western Mass
    Re: Stud broken off of turbo
    My younger brother did the same on his 1.8t this weekend. Yours look like it broke even with the outer edge of your downpipe, so you might be able to get something on it and turn it out. Chances are you'll have to remove the downpipe to do this. Otherwise a torch and an easy out is your best bet.
    Oct 13 2007
    I dont think I can get the nut on the rest of the stud thats on there. Its pretty short now. What did your brother do?
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    Quote Originally Posted by kurupt_hawaiian View Post
    what the guy earlier was saying is get the remaining part of the stud out of there and replace it with a new one.
    2008 Phantom Black TQM
    Oct 13 2007
    Yeah, i now realize what he was saying, i feel stupid. Where could i get a new stud?
    Sep 12 2005
    Western Mass
    I don't mean to put it back on, but these studs are threaded on both sides, so if theres enough of it sticking out once the downpipe is off you might be able to hit it with some heat or pblaster and remove the old stud. Audi has new ones for $4.xx something.
    His were snapped flush in the housing, so I had to heat it up and use an easy out.
    Goodluck
    Oct 13 2007
    Quote Originally Posted by Mecartay View Post
    Goodluck
    That sounds better than taking it to a shop, Ill see if i can find a new stud.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    might as well get a big turbo
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    i would probably ruin something else on the car out of anger if this happened to me... but ya if i was financially stable, i would go big turbo and forget about it. i was scared of this happening when i put my vmr test pipe on too but someone warned me about it so i was extra carefull
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by supamannn99 View Post
    Hahaha ... ROTFLMAO.
    Oct 13 2007
    Yeah...I dont think im ever gonna go big turbo. I just need to replace the stud.
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    I did the same thing on my b5. Sorry man. Have fun getting that stud out.
    ooooO..................Ooooo
    ...............oooo
    .........o.............o
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Did it on my MK4 GTI...as well as my friends as well...it sucks...hope your able to work it out...
    Jan 15 2008
    Chino Hills, CA
    lol you guys all have really strong arms
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    I broke the stud on my old 1.8T turbo. It's not that hard to do.
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Oct 13 2007
    These cars come with some weak ass studs...its more common than i thought.
    May 03 2008
    Monterey, CA, 93940
    yea def broski...u really have to soak em with something before you go to take them off...it sucks..i feel ur pain...
