History:
So I have had a boost leak problem with my car for a while...i had a apr chip then I went into limp mode and thought it was my turbo so I put in a brand new oem k04 and a fmic...and the car was still in limp mode...then I played with the hoses and then it started boosting to 15psi and gradually droping to 10 then I replaced the N75 valve and put in a catch can and now the car is only boosting to 10psi but still doesn't hold boost, no power.
Problem: Then the other day I noticed an exhaust leak...(I guess I didn't torque down the cat to turbo bolts down correctly) and the car would choke for a second when I rev'd it and you can see some smoke coming out from the engine bay from the exhaust...and it smells bad so is my CAT bad? and I hear that maybe causing my car to boost only 10lbs?
So if I put in my test pipe I have in my back seat (installed by an exhaust shop so they can torque it down properly) do you guys think that will solve my problem or is my CAT ok and I smell something else that's not letting my car boost?
