Results 1 to 40 of 56
    Sep 19 2007
    seattle
    B7 Oil Change DIY, how?
    Is there a thread (with photos if possible) on how to do it yourself on a B7 S4? If there is, it should be pinned on top of the forum...
    Sorry and I did use the 'search' function... I used wods like oil change, oil change DIY...but so many threads that were not what I was looking for came up...
    Thank you in advance.
    p.s. I googled and found the write up with pics for B5 S4 only...thanks.
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Re: B7 Oil Change DIY, how?
    Need to get under car, remove belly pan, and then you'll see a torx bolt in the oil pan.
    You drain the oil.
    Take the filter out (it's in your engine bay at the top of the engine, a huge plastic nut looking thing)
    You put the oil drain plug back on
    fill her up with 9.5 qts of the good stuff.
    You put the belly pan back on.
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    9.5 quarts! wow.
    what would that cost for 'the good stuff'?
    Mar 11 2008
    Pierceton, Indiana
    Quote Originally Posted by sakimano View Post
    9.5 quarts! wow.
    Motul Excess is liek 10$ a qt.
    Veteran Member Three Rings tatarin's Avatar
    Feb 11 2008
    05 B6 S4 Nogaro 6spd
    deerfield IL
    i use mobil1 0-40 it's about $7qt
    Jun 02 2008
    jesus
    how often do you guys change?
    I have Audicare, but wondering if I should change between 10,000 miles services
    Veteran Member Four Rings bsrpilot44's Avatar
    Feb 25 2007
    B7 S4
    So.Cal
    jesus
    I change mine every 5k...sometimes sooner, depending on how aggressively the car was driven.
    Ex: If I track the car ( 2 day event)...I change the oil right after.
    Better safe than sorry.
    -B
    Veteran Member Three Rings szinkuti's Avatar
    Oct 06 2008
    Allroad Truck aka Uber UTE
    Grand Prairie, Texas
    Its a 10 mm allen for the drain plug and 24mm socket for the oil filter cap
    Feb 11 2008
    deerfield IL
    i change every 5k if i drive like grandma during that time... and during summer i tend to be more throttle happy and very spirited :) so i would chance every 2-3k
    Nov 19 2008
    San Jose, CA
    An oil extractor (Pela 6000 or Mityvac) works great on these cars and makes the job one you can do without having to get under the car and remove the splash shield. With that it is very straightforward:
    1. Unscrew the oil filter cover (oil will drain into pan)
    2. Install new filter and 0-ring; replace cover
    3. Push extractor hose down dipstick tube, pump out oil (may have to empty extractor once if it holds less than nine quarts)
    4. Refill with about 9.5 quarts of new oil
    Recommended oil change interval on this engine is 10K miles. If you use high-quality synthetic oils, this is probably OK. Mobil 1, Valvoline Synpower, and Castrol Syntec 0 or 5w-40 are available most everywhere. European brands are good also, but will cost more (Pentosin, Motul, Total). I am going to try Shell Rotella 5w-40 full synthetic next time-- it is lower priced and seems good quality.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    9.5 quarts! wow.
    around $95 for Lubro-Moly 5-40...10liters
    i change every 5k miles
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    unscrew the oil filter first to release the oil into the oil pan. Then drain the pan So the oil in the oil circuit will flow out into the pan so u can drain everything.
    Oct 03 2007
    B7 S4, Kia Cadenza, Kia Optima
    Orange County, CA
    And if you're not going to use an oil extractor, mark the location of the drain plug on your belly pan and do yourself a favor, tape it off with blue tape and drill a 3" hole though the belly pan. You'll save yourself a lot of hassle next time you go to change your oil.
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    Quote Originally Posted by channad View Post
    Yeep, just used lubro-moly too! I heard it was the best, and seems pretty great so far. I also used an oil extractor, which made it a breeze! I did have to empty it once though, but for not having to jack the car up or remove the belly pan, well worth it. I got the mytivac through amazon for about 70 shipped.
    One other owner suggested removing the belly pan and then cutting a small hole where the oil drain screw is located, and then the next time you don't have to remove the belly pan.
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Sep 19 2007
    seattle
    Quote Originally Posted by ClarkSJ View Post
    Thank you, all.
    Ok, I do have an oil extractor. I thought I need to extract the oil first THEN replace the filter? What do you do to clean the oil drained into the pan? I assume the 'pan' you're talking about is the plastic belly under the car?
    Nov 19 2008
    San Jose, CA
    No, the oil pan. When you unscrew the oil filter cover there is a valve that will release and drain oil in the filter housing into the oil pan. You want to change the filter first, so that old oil can be extracted.
    Its a very easy engine to change the oil on with an extractor, It can all be done from the top with no mess.
    Dec 12 2008
    06' QG A4 Avant s-line
    Tristate
    Quote Originally Posted by nimski62 View Post
    You drain the oil.
    9.5?
    Sep 19 2007
    seattle
    Thank you!
    Jun 02 2008
    my dealer doesn't charge much more than that to do it for me....why bother DIY?
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    To me it's never not about the cost. I'd much rather do everything on the car my self or with help from buddies than pay someone to do it. Oil change is such a simple task and besides, the only way you'll know it was done right is if you do it yourself. You never know ... even at the dealer some douche could be having a bad day and not wanting to do a good job.
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Senior Member Two Rings EssPhore's Avatar
    Jun 01 2008
    2005 B6 S4, 2007 KTM EXC 450
    So Cal./I.E.
    Do the Oil Extractors get the same amount of oil out as removing the plug? Are the jugs on the extractors marked (i.e. 1, 2, 3, etc quarts)?
    Veteran Member Four Rings DolphinV8's Avatar
    Feb 18 2004
    I can show you while I am still in town. =)
    Sep 19 2007
    seattle
    Quote Originally Posted by DolphinV8 View Post
    Thx in advance, Carson! How long will you be in town until? I think the part where I need help is replacing the oil filter... This thing looks very different than the ones I have seen... Should I go to Barrier and tell them I need an oil filter? What else do I need from Barrier? Btw, what sizes are the tools to remove oil filter cap and other stuff?
    My car is at 4k miles so not quite 5k, yet... so if I miss you this time, we can always do it in the future since you're up here quite often... let me know.
    Sep 19 2007
    seattle
    Just wanna learn something about this car...
    Sep 19 2007
    seattle
    Quote Originally Posted by EssPhore View Post
    I heard from various ppl (google it and you'll find even bmw peeps use it, too) that it works fine... Google it and you'll find lots of reviews.
    The jug does not have any markings... that's what sucks.
    Nov 19 2008
    San Jose, CA
    The Pela 6000 holds 6 liters and has markings at 1 liter intervals.
    On my 1.8T, I ran a test by pulling the oil drain plug after uising the extractor. Just a few drops came out--not much at all.
    Mar 24 2008
    khgkhg
    Pela sells a 14 liters version which I have but have not used it on the S4 yet. I've used it on my lady's 325 and it pulled exact same amount it took to fill it. I won't change mine for another couple of months but will pull it all out with Pela and then check the pan and see if there is anything left.
    |^^^^^^^^^^^\||____
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    lol
    Registered Member Two Rings
    Jan 03 2007
    Germany
    Quote Originally Posted by 40valve View Post
    Not sure if I'm pickin up what your puttin down. If the oil level was full when you started the job, then you would only need to put in as much as you pulled out regardless of amount (1 qt out = 1 qt in, 5 qts out = 5 qts in, etc.). Maybe I'm reading into your wording a little too far, but I got a laugh out of it.
    Some people are like Slinkies - not really good for anything, but you still can' t help but smile when you see one tumble down the stairs.
    Jun 01 2008
    So Cal./I.E.
    Right on everyone! Thanks for the responses.
    Sean
    Feb 18 2004
    Quote Originally Posted by cellg8 View Post
    It's different, but it's actually a lot easier to replace it. You can get the filters from the dealer or online. I bought mine from ecstuning since I needed to get some parts for my b5 at that time. You need
    oil filter
    oil filter o ring
    drain plug washer
    according to bentley's manual, the socket size is 36mm
    I can send you all the diagrams if you want.
    Sep 19 2007
    seattle
    oil filter
    oil filter o ring
    drain plug washer
    Please do! cellg8 at hotmail
    Thank you, sir!
    John
    Jul 23 2008
    2004 Imola S4
    Westchester, NY
    I remember the first time I changed my oil on my b6, it took me 30 minutes to find the filter. That stupid plastic piece with the audi symbol on it is quite deceiving.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Here's from a thread I posted a while back and a link to the original thread.
    Quote Originally Posted by S4J View Post
    Hi All,
    I changed my oil and filter this morning. It took me 17 minutes with my larger capacity Pela Pro 14 oil extractor (I sold my smaller one to a friend).
    I though I'd share the products I used for those interested…
    The extractor is extremely easy to use (make sure the oil is warm, not hot). Just push the correct sized tube (you get three) down the dip-stick hole to the bottom and pump the handle a few times to create a vacuum. The tubes they provide aren’t quite long enough so you’ll have to raise the extractor off the groung a bit by placing it on a box or something. I use a plastic milk crate. While the oil is extracting I replace the oil filter. The filter is located on top of the engine, under the trim cover with the Audi logo, at the rear. You’ll see a black plastic domed cover with a plastic nut molded into the top…the filter is inside.
    NEW- PELA PRO 14 LITER OIL EXTRACTOR
    $109 Shipped from http://www.eAngler.com
    OLD- PELA EXTRACTOR $79 from Griot’s Garage (fine for my Z, but too small for the S4)
    OIL
    Lubro Moly VOLL-Synthese (5 W-40 Full Synthetic Motor Oil) - 5 Litres x2, $35 ea. ($83.38 shipped) from http://catalog.etyparts.com/item.wws...y&clientid=ety
    FILTER
    Mann HU 835/1 x oil filter, $15.53 ea (pack of 4, $62.12 shipped) http://www.germanfilters.com/2004-au...k-p-55729.html
    I also purchased a fuel filter but haven't installed it (I haven’t looked in to where it’s located...anyone done it?).
    Mann WK 730/1 fuel filter for 2004 Audi S4 with 4.2 V8 engine
    $12.58 each from http://www.germanfilters.com/2004-au...r-p-47526.html
    Hope this helps, have a good one…Steve
    http://www.audizine.com/forum/showth...ghlight=minute
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    So with an extractor, you don't need to replace the drain plug?
    /S4
    AWE l Koni l H&R l Hotchkis l VMR l LEDs by fly
    Active Member Three Rings DuncanC's Avatar
    Oct 07 2008
    Visit me on EuroAddiction.net
    Edmonton, AB
    If you use an extractor you drain plug never comes out.
    Sep 19 2007
    seattle
    S4J, very helpful. Thank you!!!
    Mar 24 2008
    khgkhg
    Quote Originally Posted by meinblaus4 View Post
    What I meant is that the extractor pulled out everything out. A lot of people say that it will not do that. Her car takes 7qts and that's how much the extractor pulled out. 7qts went in.
    Not like I pulled out 5 and put 5 back in
    My whole point being it pulled all of it out.
    |^^^^^^^^^^^\||____
    May 08 2009
    Holmdel/NJ
    To revive the thread, a question. Using the oil extractor, do I need to remove the oil filter before the extraction, during or after. Does it matter at all?
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    Quote Originally Posted by fructus View Post
    from what ive read so far, it does not matter. Oil extractor FTW.
