Results 1 to 8 of 8
    Established Member Two Rings endlesswinter77's Avatar
    Dec 31 2008
    01 allroad 2.7T 6MT, sold: 07 IW A3 3.2
    The North West
    Question Break Pad How-To?
    Ive got a A3 3.2 Quattro, and the rear break pads are getting low. thinking about trying to do them myself. Any one have any comments on attempting this myself, and does anyone know of a good how-to/tutorial for it?
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Re: Break Pad How-To?
    I do not have an answer to your question..... But I have a 3.2 also, and was wondering how many miles do you have, and have you done the fronts already? I have 32000 on mine, and just ordered my rotors and pads. It looks as if there is a lot of life left on my rears... And, I am doing my own install as well.
    I do know that you should get the tool for the piston on the caliper for the rear... It comes out different than the front, hence the parking break. you can get it from ecstuning.com
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Veteran Member Four Rings krazyboi's Avatar
    Oct 24 2006
    NoVA
    Here you go fellas. I got a A3 3.2 as well and used this. Its exactly the same.
    http://www.golfmkv.com/forums/showth...rear+brake+pad
    Jun 05 2008
    Houston, TX
    thanks for the link...very helpful!
    PAST:
    Dec 31 2008
    The North West
    Yes thank you!
    Anyone know if there are any major concerns when installing pads? like any steps that are easy to F up, or cause damage if you dont do it right? After reading through the tutorial it seems pretty straightforward. Thanks
    Oct 24 2006
    NoVA
    I've never changed brake pads before and using this guide I was able to do it easily and do it again in the future.
    I guess the best thing to have is leverage. If you don't have access to a lift, make sure you have tools that give you enough leverage to work the bolts out. Mine were quite a pain to remove. Maybe use some spray to loosen up some rust.
    Also, be gentle w/ the brake sensor connection on the driver side. I was a bit rough and mine broke
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    The tool is essential for Audi rear calipers. I built my own that works but I shuold have just bought a proper one. The pistons cannot be pushed in without the tool IMO, unless you have incredible strength to apply pressure to the piston while turning the wrench.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Registered Member Two Rings Jim@STaSIS's Avatar
    Sep 22 2008
    sonoma, ca
    DO IT DO IT. very easy diy, get a 30$ brake tool [i got mine from harbor freight] and a 6pack and you're in business. remember to use jack + jackstands [jack alone = no good]. hit it all with some pblaster if you're in the rust belt, but with a car that new you shouldn't have any issues.
    you'll feel like you accomplished something and save yourself some dosh!
