There is the wiring harnesses, the PCV and SAI piping as well as a metal hardline running below it that also mounts to the lower bolt of the flange.
If you remove the coil packs, the airbox and unclip/unbolt the wiring running to these (SAI pump, MAF, evap solenoid, WG solenoid and the coils). You can then remove the PCV 3-way tee that is attached to the back of the valve cover. It'll take some fighting but getting it off will gain some room. You may have to unbolt the two black metal hardlines running along the exhaust side of the head which are a part of the SAI to get enough flexibility. After all of that is out of the way, the only hold ups should be the SAI valve assembly and the metal hardline below the flange. It will be easier if you can remove the SAI valve as well (3 bolts) but you should be able to work around it with a small ratchet and a small wrench.
It is easy with simplified emissions, I need to do mine and the only thing that is slowing me down is I cannot be bothered to drain the coolant. For the record, my flange is being changed for the first time, at 82k miles.
