Results 1 to 10 of 10
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    ETKA request: B6/B7 S4 front brakes
    Any help w/ this request would be greatly appreciated - TIA
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    In Limbo Two Rings
    Jan 17 2009
    Nor*Cal
    Re: ETKA request: B6/B7 S4 front brakes
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    Quote Originally Posted by shop.dthaus.com View Post
    Are they seriously $1200?? might as well go legit bbk for another 500 or so. I could see maybe 7 or 800 for an s4 upgrade, maybe I'm thinking of b5 s4. Whats the difference?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by thebikedoctor33 View Post
    brand new. yes. That price is very reasonable.
    Used, you'll be lucky if you can find them for $500. There is a set of [used] B7 S4 calipers in the classifieds for around $500 right now. Then you need pads (>$100) and rotors (>$100-150 each).
    When it comes to brakes. My motto is to not cut corners. Granted, there is a brake kit out there for each individual's use (BBK isn't necessarily the answer).
    -Doug
    Dec 20 2006
    8VS3
    Thanks for the offer on the new kit...$1200 may be the going rate, however, it's a bit "too beaucoup" given the relatively low cost of BBKs nowadays.
    I'm checking what pieces are involved so an ETKA would still appreciated.
    In Limbo Two Rings
    Jan 17 2009
    Nor*Cal
    Caliper(l) 8E0 615 123 B (C) B is silver, C is deep black
    Caliper(r) 8E0 615 124 B (C)
    Carrier (2 needed) 1K0 615 125 B (C)
    Hardware (2 needed) 4D0 698 647
    Spring (2 needed) 8E0 615 269
    Disk (2 needed) 8E0 615 301 T
    Pads (1 set) 8E0 698 151 C
    Splash Shield (l) 8E0 615 311 C
    Spalsh Shiled (r) 8E0 615 312 C
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Arclight View Post
    So, you spend $2k on StopTechs (cheapest BBK). They are StopTechs. Not OEM. Granted OEM doesn't have the 'bling factor' that BBKs provide you but they work very well. Something about OEM Brakes speaks for itself when bolted up on an Audi.
    -Doug
    Dec 20 2006
    8VS3
    Thanks DTHaus, a kudo for you.
    Do you happen to have the screen print as well?
    Also, what is the Part # for the the hardline that goes between the back of the caliper and the "L" bracket (thanks MikTip for the picture):
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    holy crap didnt know s4 brakes were that much!!!
    I really got a killer deal on my setup then,,, Thanks 10mpgS4!
    another stereotypical Audi
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    I just got all four calipers from a B6 S4 from Shokan with the splash shields for $1000.00. His price is fair for new. The B6 calipers I got are going to need to be painted, his are already done. It's a very reasonable price for what you get.
    I'm going to do up the set I just got, then swap them onto my S4 and do up the ones that come off, then upgrade the brakes on my Avant. BBK's are nice, but the stock S4 brakes are pretty ferocious as far as stopping power goes, especially if you go all the way around with them.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
