Results 1 to 11 of 11
    Veteran Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    Question Feeler for some SSR Comps
    Mods: I dont know if we are still allowed to post feelers here or if it needs to be in classifides, so if I'm wrong please delete this thread.
    Guys, I have a set of SSR Comp Type C-RS's that i'm thinking about selling. I'm just throwing this up as a feeler to see what pricing I should be looking at. These are in fantastic shape, I've only seen one scratch on there, and it's no bigger than 1mm in length and no deeper than a surface abrasion. I also have a set of Khumo MX's that might be at 50% (I haven't looked in a while). One of the tires has a plug.
    SSR COMP TYPE CR-S
    Color: anthracite
    Demensions: 17x8.5
    Offset: ET33
    Weight: 16.5 lbs
    Quality: 99.8%
    Khumo MX
    tread: ~50%? (i'll check tomorrow and let you all know)
    quality: No curb-rash, one tire has a plug
    I'll get clean pictures of the rims tomorrow.
    Center Cap
    Here is the scratch that I mentioned above.
    The Valve Stems are embossed with SSR and they are lightly glossed black, even though they look silver in these pictures.
    A few random pictures and angles of each of the wheels and the stamping.
    Here are a few pictures of the stickers (2) I messed up which I can get replacement stickers for.
    Pictures of the width of the tires and stance on stock suspension.
    Last edited by laxman851; 01-25-2009 at 04:13 PM. Reason: -needed to add more information
    Veteran Member Three Rings Go_S4's Avatar
    Mar 20 2007
    Nor Cal
    Re: Feeler for some SSR Comps
    post pics ..
    Jan 09 2008
    2001 S4
    NC
    Quote Originally Posted by Go_S4 View Post
    post pics ..
    Here are some I found. I'll take pictures of the wheels and tires tomorrow morning.
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    ygapm
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    Do you have any problem with rubbing with that size tire?
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Jul 26 2008
    Jersey
    if only they were 18's
    Jan 09 2008
    2001 S4
    NC
    Quote Originally Posted by Jung View Post
    ygapm
    ygapm?
    Quote Originally Posted by elijahallen View Post
    I run on stock suspension with an H-Sport front sway bar and the only rubbing I’ve experienced was a few high speed runs on a parkway back home that had some big dips in it (rubbing in the front, and its very minimal), and slight rubbing on either rear tire (depending which way you turn) with 4 and 5 people in the car under hard turning on banked turns, but that was before I put the sway bar on, it managed to reduce the body roll enough to keep it from rubbing. The rubbing caused from the dips in the road were also only on the inside of the fender, if I had rolled my front fenders it wouldn't of rubbed at all.
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    if my translation is correct I believe YGAPM= you got a personal message(PM)
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    i like the look, close ups?
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Jan 09 2008
    2001 S4
    NC
    Quote Originally Posted by Chknkatsu View Post
    Yeah sorry about that, they are a little dirty right now and I need to get new stickers on two of them because I pressure hosed part of the damn SSR sticker off. I'll take some as is wheel pictures right now, and put them on in a few minutes. I'll get good clean pictures tomorrow in better light.
    Registered Member Three Rings updaboost's Avatar
    Mar 08 2006
    S4, 997 4S & S2000
    Chicago
    I'll buy your center caps. PM if interested..
    01.5 Nogaro Blue S4, 6sp
    VAST Stage 3 - Piggies - Neuspeed - RS4 Clutch - Samco - Hyperboost DVs - AMS TBB - Stratmosphere SS - Flik Justice/SSR Comps - Vogtland - AWE DTS - H-Sport Sway
    360whp/400wtq
