So for the last month or so my clutch has been slipping in the cold cold weather under 40 degrees. It will only slip when I get to about 10psi. The clutch only has 30k on it and its a clutchmasters stage 4. My question is the clutch done or is it some sort of hydraulic system problem. The pedal works fine and it goes into all gears without problems. When its over 40 degrees it will only slip in the higher gears under a heavy load.
