    Veteran Member Four Rings ray-ray's Avatar
    Jul 08 2004
    Moreno Valley, CA
    adjusting height on my coilovers
    Hey guys,
    i installed my stasis coilovers, but after i installed them, i am having a hard time adjusting the height. what advice do you guys have to make the height adjustment easier?
    i am using the tool that comes with the kit, but there isn't a lot of space to work with when im trying to adjust the front and rears. any help is appreciated.
    Old Car: 2003 Audi A4 1.8T Dolphin Grey with AWE GT28R Turbo Kit
    New Car: 2008 Audi A4 2.0T Quattro Ibis White, GIAC X-Flash from Torque Factory
    Established Member Two Rings dpoor3ch's Avatar
    Jul 10 2008
    B6 UltraSport, BMW X5 Sport
    Charlotte, NC
    Re: adjusting height on my coilovers
    I just intalled a set of ST Suspensions coilovers (galvanized version of the KW variant 1). The Fronts were very easy to adjust; Just jacked it up, loosened the allen screw and used the provided wrench. The rears were much more difficult. Mine couldn't be adjused just by using the wrench while the car was jacked up. Had to loosen the subframe a bit.
    04 USP 3.0 | VMR RS4 Gunmetal | ST Suspensions Coilovers | Tint | Shaved Emblems | Soon to be supercharged
    Jul 08 2004
    Moreno Valley, CA
    Quote Originally Posted by dpoor3ch View Post
    what allen screw are u referring to for the fronts?
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    the stassis has two spindle things in the front... one to adjust height and the other(lower smaller one) to lock the top one in place. others like my startup gts has only one where it locks with an allen screw. mine are sorta stripped in the front but fine... and the rears are alot easier to adjust than the stassis. i had to loosen the subframe like dpoor mentioned to adjust the rears on my stassis.
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Yeah it took me FOREVER to adjust the height on the stasis. I still have some adjusting to do cause my left side rubs like crazy!! I guess i need to loose some weight or something but it rubs hard when i make right turns on freeway off ramps and on ramps.
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
