Results 1 to 21 of 21
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    back from the dyno...
    Dyno Dynamics dyno's are called the heartbreak dyno for a reason... but still I was expecting more. the car is stage 2+, (unknown)software, catless turbo back exhaust, IPP intercoolers, EVOMS intake... and this is all she made:
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Veteran Member Three Rings Justin:NorCal's Avatar
    Feb 08 2008
    2000 Audi S4 (new build), 2000 Audi S4 Stage 3 (stolen last year)
    Dublin, CA
    Re: back from the dyno...
    That is not bad for stage2+ be happy.
    Arlington, VA
    Thanks, its ok I guess. the software is just a little conservative, I could upgrade to something more serious like GIAC... but do I want to put that extra stress on my 95k mile turbos? its a hard decision...
    Now: 2011 Audi S4
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    looks good
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    actually this dyno seems to read spot on. That puts you at about 320 crank I think. I think with a stronger chip you may make a bit more. Be happy, these are good numbers for pump gas
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    yeah man this isnt too bad
    im gonna go on a heartbreak dyno soon too=\
    hahah
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Q7, Q7, F-type manual
    not bad considering i have seen a full stage 3 put down 300 and a b7 s4 put down 225 on a dyno dynamics.
    Arlington, VA
    here is a little clip I put together real quick... no the GTR did not dyno
    http://www.youtube.com/watch?v=t6aTrG7pDBM
    Now: 2011 Audi S4
    Jan 11 2007
    Salt Lake City, Utah
    Yeah, don't stress at all. I have a similar setup (2+, GIAC, catless ASP DP's, APR exhaust) and on race gas on a killer mustang dyno my max hp was like 227. Use it as a baseline and a tool for any future upgrades to gauge gains. It's tough to compare different brand dynos that are each calibrated differently anyways and at different elevations. Looks good!
    Oh, and any bigger pics of your avatar? I'm going to be doing a similar paint scheme with my y-pipe and bipipe shortly.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Established Member Two Rings G.O.A.T.'s Avatar
    Jun 22 2007
    2001 S4 STG2+
    Ontario,CA
    got back from the dyno myself. DynoJet at 250awhp and 304tq. I was boosting 8pds on a GIAC Xplus, G2 Neuspeed exhaust, piggie pipes, itb intake. Also I have leaks, intake mani gaskets and all other gaskets are done for. 2 coils are done for and throwin codes. The tech said I'm losin massive amounts of power and I very much agree. My A/F was 8 instead of 11. So STG 2+ at 250...not so sure thats accurate, you should get it tuned man.
    Also after the dyno the following tuesday i got it reprogrammed with an updated GIAC xplus file. Boosting 23pounds now.
    Wonder what I'll be pulling now minus all the stuff going wrong. One things for sure, not 250 or even 260
    Liberating Horspower...one mod at a time
    http://www.straferight.com/photopost...-jiggle-02.gif
    Jan 11 2007
    Quote Originally Posted by G.O.A.T. View Post
    got back from the dyno myself. DynoJet at 240awhp and 304tq. I was boosting 8pds on a GIAC Xplus, G2 Neuspeed exhaust, piggie pipes, itb intake. Also I have leaks, intake mani gaskets and all other gaskets are done for. 2 coils are done for and throwin codes. The tech said I'm losin massive amounts of power and I very much agree. My A/F was 8 instead of 11. So STG 2+ at 250...not so sure thats accurate, you should get it tuned man.
    Not sure if that first boost figure is a typo, but if you were only boosting 8lbs and you were 240whp, I'd dare venture to say that's a happy dyno. You should really get your boost leaks checked because it's def not healthy to run 23lbs of boost on KO3's (assuming you have KO3's).
    LOOKING FOR:
    Jun 22 2007
    2001 S4 STG2+
    Ontario,CA
    I should be around 288awhp from what I have. The guy who had the car before me was a friend of mine. The first figure is not a typo. I was boosting just about 8 pounds on the meter and my gauge.
    It's the 2nd page, pearly. Also there is a dyno chart attached to a post. Running hella rich
    http://www.socaleuro.com/forum/showthread.php?t=38869
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 25 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    I made 283awhp on 034's dyno which was on ca 91oct MTM stage 2 software. Dyno was called dynomite not sure how that compares to a mustang dyno.
    Jun 22 2007
    2001 S4 STG2+
    Ontario,CA
    typo on the hp...actually i was pushing 250awhp.
    Jan 11 2007
    Correction, should be around 288.3527awhp.
    Unless you know what other stage 2+ S4's made on that particular dyno (not just the same brand dyno) you really can't make too specific of a guess of where you "should" be at (unless of course the guy you bought the car from dynoed it on that same dyno when the car had no issues.) The dyno arguements will never cease, so it needs to be reiterated that there will always be differences between different dynos and dynoing conditions, therefore getting too specific when comparing #'s from different cars on different dynos/conditions is in vain. You could say his in inaccurate, he could say yours is inaccurate, it's all relative (until you compare both to a dyno that is 100% for sure scientifically accurate.)
    Having said what I said above, I still say that dyno reads high. I can't imagine stock boost with a turboback exhaust and upgraded intercoolers netting ~55 crank hp, unless the program really advances the timing or something.
    Beautiful car BTW
    LOOKING FOR:
    Jan 11 2007
    Emphasize what I said even more then
    LOOKING FOR:
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Quote Originally Posted by revhards4 View Post
    I agree.
    Using a standard 28% drivetrain loss that puts you (OP) at 321hp & 371tq...sounds pretty good.
    With the IC's, it should be pretty consistent on the street too, which is what really matters.
    Brilliant Black 2001 S4 - 6MT <3
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    that dyno reads very conservative.
    saw a modded b6 s4 put down 240whp.
    stock evo put out 190whp.
    i wouldnt worry myself with dyno numbers. only for comparison on the same dyno.
    Feb 09 2008
    imola b5 s4
    minneapolis
    can definitely only compare cars and numbers that were run on the same dyno, the same day, under the same conditions. I ran my car on a dyno jet and put down 281awhp/311tq on APR Stage 2+. My buddy with the exact same setup ran on a mustang dyno and only put down 232awhp/295tq. It was two different dynos, one in extremely hot weather and one in extremely cold weather. There are so many different factors to dynos and the numbers they put out it isnt even funny. You need to compare apples to apples...
    Veteran Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    EilTTe: Did they run i flow fans infront of your IC's? I didn't see them on that video that might be one more reason for slightly lower output.
    Also don't mean to thread jack but are going to the Eurowise dyno day on 7 Feb?
    Arlington, VA
    Quote Originally Posted by laxman851 View Post
    They had one large fan infront of the car. I'm not planning on it since its a 2wd dyno
    Now: 2011 Audi S4
