Results 1 to 38 of 38
Thread: boost problem
    Veteran Member Four Rings wannabeS4's Avatar
    May 14 2008
    01 S4 Avant
    New Hampshire
    boost problem
    I have a boost problem. I have stfa and didnt find the answer I was looking for. I have pressure tested. I boost 5-6 psi in all gears.
    I found a leak on the brake booster line where the line creates a T. Another thing is when Im stopped at idle my vacuum reads 21 but when Im driving it reads 24. I also have my cel light on. Would the leak in the brake booster cause these readings.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: boost problem
    Are you chipped or stock? You need to know what the CEL is for, you could be in limp mode because of it. A leaky brake booster hose is a common area for leaks.
    08 S4- Stock SOLD
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    im stock, and I have a vag com cable in the mail so i will know shortly. I thought limp mode was limited to 5psi.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: boost problem
    Quote Originally Posted by wannabeS4 View Post
    Limp is like 5-6psi max. Maybe someone in your area can scan the car for you, an autozone or the like could also do it.
    08 S4- Stock SOLD
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    I will have to check out autozone to see if they can scan the car. What would cause the change in vacuum?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: boost problem
    A leak, probably
    08 S4- Stock SOLD
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: boost problem
    DING DING Correct answer^^
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Four Rings adr3naline fix's Avatar
    Dec 17 2008
    Sold 01 1.8T, 05 Mini Cooper S JCW, 04 ZX10R Track
    Milwaukee
    Re: boost problem
    What do you normally boost at?
    N75 valve clear? Unplug it and drive for a bit. If you boost above that6psi it may be your N75. Remember to not go WOT when it is unplugged
    MAD dirty/bad? Try running without it, if problem persists, it's not your MAF
    My car is SOLD
    2001.5 1.8TQM || GT2871R Hybrid Elim @ 24psi | Unitronics Custom | 307awhp | etc | $15k+ in parts alone
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    Ok so something new, went wot today and saw that I was boosting over 15psi, the boost levels would fluctuate from 11 to 18 psi. Im thinking it may have something to do with the n75 valve. How can I tell if thats bad?
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Re: boost problem
    Its your N75 bro, I have the same problem, I talked to Jay at JHM about this a while ago and he also said its the N75
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    alright cool, is that an easy fix.
    Oct 31 2005
    Ashburn
    Re: boost problem
    3rd item listed. You might be able to find it somewhere cheaper, but yeah it is an easy fix
    http://www.ecstuning.com/stage/edpd/...ategory=Engine
    - Instagram: @Sinister_rs5-
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: boost problem
    wait you said you were stock?? Your obviously not stock and chipped because stock boost levels are 8-9psi while chipped could vary from 15-16 with spikes to 18-19...
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: boost problem
    before you order the n75 i'd wait and get it vag'd to see what codes you are actually throwing.
    if you have an intermittant egt sensor that is bad it will throw your car into limp mode and will boost sometimes at 5-6psi when in limp mode and other times it will boost normal. This also fits the description of your problem.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    Re: boost problem
    Is there no way of logging the EGT's readings??
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: boost problem
    Quote Originally Posted by Caddy7 View Post
    Sure, block 112. They should read 1035 engine off and 945 with the car running. Anything else and they are going bad.
    08 S4- Stock SOLD
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: boost problem
    cant believe you pointed him to the stock valve. the 'H' Valve is a MUCH better solution and on ecs is even cheaper right now.
    http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T
    another link to it with the part #
    http://www.worldimpex.com/parts/genu...id_117475.html
    op; im gonna co-sign on the 75 valve being bad.
    Oct 31 2005
    Ashburn
    Re: boost problem
    Quote Originally Posted by ThirdStrike View Post
    H valve? Your talking bout the N75 race valve right. I thought there was a thread awhile ago about. Alot of people that bought that H valve returned it cause there car would boost to high or something. For k03's the stock N75 valve should be good.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: boost problem
    the higher spike is what the valve was designed to do. if you dont like higher spikes then run a mbc in parallel. i still say H valve is better. stock turbos or not. this is my experience, not based off what others said..
    May 26 2008
    Riverside, CA
    Re: boost problem
    Quote Originally Posted by mholme View Post
    Thanks, is there a way to log the N75 also?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: boost problem
    119
    08 S4- Stock SOLD
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    Quote Originally Posted by 00s4slvr View Post
    My boost doesnt always hit the same psi, sometimes it hits 12psi and some times and I can hit 18psi, so Im pretty sure Im not chipped, wish I was. Well once I get my vag com cable I will scan it. I do have a cel light on so I am throwing a code. It should be a couple days.
    Oct 31 2005
    Ashburn
    Re: boost problem
    What he's saying is if you weren't chipped you should only be hitting 8-9 psi max and maybe a 10psi spike. but if your boost is any higher than that you def. are chipped. 18psi meens you are chipped. Might want to try and find out what software you have.
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    So what your saying is if I was stock and my n75 valve was bad I would still only be boosting 8-9psi.
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Re: boost problem
    Exaclty
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    So Im chipped!!!!! so the n75 valve would cause the boost to fluctuate. How would I go about finding out what software I have.
    May 26 2008
    Riverside, CA
    Re: boost problem
    119
    Do you happen to know what walues is normal?
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: boost problem
    First of all i told you that if your over 8-9 psi then your chipped way back in the thread lol. Second it seems like your n75 valve is bad cause i had a similar issue exact mine would hold 15 spike to 18 then drop to 12 then back up to 15 and continue. Bought a new STOCK n75 valve and that fixed the problem.
    About finding out what software you have, My money is on giac.
    Since you said you bought a Vag cable download the giac flashloader for free. Try reading and if the flashloader reads then you have a giac chip. If that doesnt work then try to hold the set button on the cruise control stalk and hold it for about 7 seconds and if the check engine light blinks then you have apr software.
    As for other tuners im not sure how to go about that. Maybe take the ecu out and see if there is a tuners sticker on it??
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: boost problem
    Nope. You actually have to log requested vs actual boost as well at the same time to tell if it's doing it's job. Here's some diagnostic info:
    http://s4wiki.com/wiki/N75
    08 S4- Stock SOLD
    May 26 2008
    Riverside, CA
    Re: boost problem
    NICE!!! that was some good reading right there.
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    well its not apr and there were no stickers on the ecu, so my guess is on giac.
    where is the best place to order the valve from
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: boost problem
    well its apr and there were no stickers on the ecu, so my guess is on giac.
    What..and what? Did you get the car scanned for the code(s) yet?
    08 S4- Stock SOLD
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    no I havent scanned it yet, why?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: boost problem
    Because your CEL is on? You probably want to know what the code is for before throwing money at the car.
    08 S4- Stock SOLD
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    well I wasnt going to buy it yet just doing some research.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: boost problem
    Just going by what you said in your previous post. Get the codes read first..
    08 S4- Stock SOLD
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    Ok so here are the codes that came up when I vag my car
    17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28): Incor. Correl.
    P1347 - 35-10 - - - Intermittent
    17535 - Fuel Trim - Bank 1 (multi) system too rich
    P1127 - 35-10 - Intermittent
    16486 - 16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - Intermittent
    Also the giac flashloader program didnt work. So now it is just a guessing game to find out what chip I have.
    May 14 2008
    01 S4 Avant
    New Hampshire
    Re: boost problem
    after I cleared the codes and went for a drive. The cel came back on and I scanned it again and the only code that came up was the 17755 camshaft sensor 2/ engine speed sensor
